Pen Holder
Old Apr 26, 2023 | 04:19 PM
  #31
MrZenLending's Avatar
MrZenLending is infamous around these parts
It worked fine when I put it in the right way. When I put it in the wrong way is when it got stuck. Do you think this would work as there did not seem anything wrong as it worked fine when I did it the right way but it stuck when I put it in backwards.
Old Apr 26, 2023 | 04:29 PM
  #32
J doubleU's Avatar
If it was easy before the correct way you should be able to insert a small pick or tool into the hole and gently press downwards then using your index finger from the bottom press up and out. I've done it a few times before.
Old Apr 27, 2023 | 11:12 AM
  #33
Thanks, it worked!
Old May 2, 2023 | 09:38 PM
  #34
GWP's Avatar
GWP
5 Year Member
GWP is infamous around these parts
My 2014 V8 Vantage has the pen, not the sport button.
Curated Content Editor
Apr 25, 2019 03:55 PM
telum01
Jan 6, 2016 02:59 PM
dertizjos
Apr 5, 2013 09:12 PM
Fyn
Northwest
Jan 30, 2011 01:33 PM
Aston Man
Feb 27, 2008 02:38 PM
