Air Bag Rattle Fix?
Old Jan 22, 2016 | 06:11 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Air Bag Rattle Fix?
My 2007 Vantage steering wheel hub air bag rattles. In warm weather the soft rubber Michelin PSS tires conceal the issue, it is as if it does not exist. When cold temperatures return the harshness exposes it at every pavement irregularity.
Has anyone attacked this problem as a DIY project...how did it go?
I have a fear if things that can explode and am reluctant to "jump right in".
Old Jan 22, 2016 | 10:58 AM
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
Here's the workshop manual pages to stop the airbag rattle. looks like you don't need to remove the airbag, just add a bushing to the attaching screws.
ID:	438000   Click image for larger version
Old Jan 22, 2016 | 11:11 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
I have had this, get the two plastic inserts from Aston bits UK they are easily fitted with a Allen driver and the fix takes less than 10 mins, it's the best thing you can do, I find rattles very annoying, and that one in the steering wheel is the worced, the parts are like 2 pounds inc shipping or you can turn them from aluminum if you have a lathe.
Old Jan 23, 2016 | 05:13 AM
flinder's Avatar
Quick/excellent responses
Thank you Jeff 335i and captain Greg. Yours are great responses to my problem. Excellent and quick can not be beat. My rattle is as good as gone!
Old Jul 7, 2016 | 10:59 AM
3Banana's Avatar
3Banana is infamous around these parts
If you are doing it yourself
1. it is a torx bolt not an allen headed bolt
2. the bush needs to be id = 8mm, od = 10mm and just slightly shorter than the unthreaded portion of the bolt
If you use the Aston bush it is only half the length of the unthreaded portion of the bolt and when it rides up the bolt and it will not push against the sides of the steering wheel back and will rattle again
Old Jul 7, 2016 | 12:59 PM
just get the two bushes from aston bits...you will work it out fast we who have done this do not need to overthink the matter just trust u on this one
mmmazing
Cayenne 958
214
Nov 28, 2020 09:56 AM
mkzhang
May 15, 2019 12:30 PM
Tuscani66
Cayenne 955/957
15
Sep 23, 2017 08:57 PM
mblueracer
Dec 3, 2015 01:37 PM
