Used Vanquish 2014, worth it?
Gents,
I own a vantage 2007 and I'm a very happy owner.
Business is good so I've been looking to change it for a new Mclaren 570s or a Huracan Lp-580-2(good pricing).
There's also 2-3 Vanquish 2014 here in Canada on the market with really good price.(Around 200k$ CAD)
While the Lambo command a larger price(around 250k$ CAD fairly equipped), the depreciation will be around 10-15/per year and probably around 15-20/per year for the Mclaren (230k$)
So as much as I like Aston Martin, here are my fears concerning the Vanquish Plan:
- Aston Martin will introduce the new generation of AM cars at the end of the year with the db9 successor. I'm pretty sure it will priced around 200k$ and will rock the new design with the amg engine... I'm not sure the Vanquish will hold in the 'look department'...
- The 2014 Vanquish comes with the 6 speed gearbox witch seems to be really bad based on many reviews. They upgraded it for the ZF 8speed in 2015 so I'm guessing there wont be any demands for a 2014 in 2-3 years when I want to sale mine...
- Lastly: DEPRECIATION; man those things are falling like a rock: at the moment we are looking at a 200k$ 2014 Vanquish that was paid around 350k$ 2 years ago... While I wont get that large part of depreciation I still think this car will be worth 125-130k$ in 2-3 years(based on current 2011 DBS selling for 130k$) so I'm looking at something between 30-40k$ depreciation/per year.
With all that negative, I still love the Vanquish, it's breathtaking but the financials just doesn't add up? Am I right to think that way?
Someone looking to buy a used 2014 Vanquish too?
Regards
Regards
Firstly, they are both ZF boxes; 6 or 8 speed.
The 6 speed works perfectly fine based on a test drive I took, especially in Sport mode. Also, many who have the 8 speed have complained about clunking during shifts from 1 to 2. AM/ZF are working on a fix, but nothing yet.
DB11 will have a twin turbo'd AM V12, not an AMG engine.
Personally, I'd go with the 6 speed. For an autotrans, who really needs 8 gears?
Typically a 6 speed has 3 or 4 acceleration ratios, a 1:1 ratio (or close to) and 1-2 over drive economy ratios.
An 8 speed can have 5 acceleration ratios. More is better.
Granted this depends upon the gear ratios selected by the auto maker, but as a general rule, makes for a significantly quicker car.
8 is better than 6. Closer ratios = quicker acceleration with less "dead" spots and better response to throttle inputs.
Not sure how you can dislike this transmission. It's a 6speed auto. Perfect for the platform. The 8 speed transmission belongs in a luxury car in my opinion. It was a complete waste of redesign. 8 speed is pointless in the vanquish.
An Aston is never going to be the fastest car in its peer group, so who cares. Much better to have a good 6 speed than a clunky 8 speed. Unless you've driven both, you don't know what they are really like. Journalists know jack, so they end up passing on lots of misinformation about what it's like to drive a car, and then the public says things like the 6 speed is bad....all BS.
Agreed. When did the 6-speed become a bad transmission? Seems like people are all excited about something new and assume 8-speed is better because it's newer. Never actually even owning or driving the two to compare. My Alpina has a 8speed transmission and that was done by the manufacture to increase fuel economy. Look at the new GM 7 speed manual. Garbage!!! 6speed is the way to go in a performance car. Auto or manual.
I drove the new 8speed vanquish and can tell you I was very disappointed as I expected it to feel diffrient drom my dbs and it wasnt, At all. With that said its a sexy *** car and I wouldn't mind owning one
I've seen a few in the low 170s and one just sold for 159K at least I think it sold as it's not listed anymore.
The ZF unit is highly regarded in other models and a software update can address "clunkyness".
A half second quicker to 60mph is very significant no matter if you're the slowest in your peer group.
I never stated a 6 speed is bad, but a ZF 8 speed can transform a car if tuned properly.
Except it hasn't so far and apparently may never be solved when mated to the Vanquish V12. I'll stick with the old 6 speed, thank you very much.
Just my 2 pence. I haven't driven a Vanquish so I'm not familiar with the car with either transmission.
Meanwhile an 8speed made a vast difference in both the Corvette and the SRT-8/Hellcat Dodges. Not to mention all the other vehicles it is offered in.
So 3 ratios before a 1:1 and 2 overdrive are ideal?
And 99% of the time the 8speed will outperform the 6speed by virtue of tighter gear ratios, all else being equal. The performance benefit assuming tighter ratios is undeniable.
0-60 times are pointless in 99% of situations. It's easy to get improved times to 60, it's a matter of tires, gearing, etc. Those are easily tweaked to give a better 0-60 for marketing. But that's all it is - marketing. Drivability is by far more important. Shifting smoothness, gear selections/timing, matching the gearing to the engine... that's what matters.
Because it's special? Yet Bentley was able to do it with their W-12?
Yes. The issue is common to the Vanquish and Rapide, but does not occur in the Bentley. Has been 8 months or so, and no solution from the factory, so they say live with it.
