Anyone have a link or process for V8V coolant change?
Old Feb 8, 2016 | 07:34 AM
boxercupdave's Avatar
boxercupdave has a spectacular aura aboutboxercupdave has a spectacular aura about
I looked through the frequently asked questions and didn't see a post for a coolant change. As part of my annual service I'm changing out the thermostat with the Jaguar part. I'm almost done with the thermostat change and thinking I should drain the rest of the coolant and fill with new while at it.
Dave
Old Feb 9, 2016 | 07:34 AM
I take it from no responses that there isn't anything special required for a coolant drain and refill on this car. I wasn't sure it there were any additional plugs to remove or a specific process to bleed the system.
In my American V8s I usually drain through the rad drain, remove the top rad hose from the thermostat, then fill through the top hose until I see fluid at the thermostat housing. For me this has minimized air bleeding.
For the Aston I will try to drain at the rad then slowly fill through the reservoir as that appears to be the highest point.
Dave
Old Feb 9, 2016 | 07:36 AM
telum01's Avatar
Sorry, haven't done that job. Replacing the thermostat is super easy (I did a write-up and vid, easy to find). But I just top-off the coolant when doing it, not a full flush. I should probably do one this year, though...
Have you looked for the process in the workshop manual?
Old Feb 9, 2016 | 07:46 AM
I used your post to do the thermostat yesterday thanks. Was thinking while I'd already drained some of the fluid why not continue on.
Guess I need to go through the process and download the manuals.
Dave
Old Feb 9, 2016 | 07:55 AM
OK just found this post so I think I'll just refill with DEX cool for now and see about how to do this properly. Maybe I can use my old vacuum pump I've used for pulling down AC systems to pull a vacuum on the cooling system.
https://www.6speedonline.com/forums/...w-coolant.html
Dave
MadWhip
Feb 2, 2016 10:20 PM
absolutionrome
Jan 24, 2016 07:25 AM
hodie21
Jan 20, 2016 04:34 PM
rwm514
Cayenne Turbo
Jan 17, 2016 09:30 PM
