Wind noise, passenger or driver's side
Old Feb 23, 2016 | 05:42 PM
slxkrdb9's Avatar
slxkrdb9 is infamous around these parts
Wind noise on AM cars is often a nagging problem for owners. Unless window seals and window height is an issue needing fixing or adjustment, wind noise may well be caused by wind vortex around the rear view mirrors. For those with automatic folding, do so while driving to check any difference when folded in. If so, the likely cause is vortex around the trailing edge of the mirror housing and the edge of the mirror, specifically the space in-between allowing wind vortex to curl inside the housing that causes often a whistling type of noise typically above 50mph. To mitigate noise, seal or reduce the housing-mirror edge gap. I did so, and the noise disappeared.
On an exclusive brand like AM, such noise should never occur and suggests 'gaps' (pardon the pun) during the design process. Hopefully, AM addressed this issue with newer models.
Old Feb 23, 2016 | 08:40 PM
cuddapah's Avatar
cuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond repute
My 2015 DB9 (bought it new) had this issue. After adjusting window seals at lease twice, I was told that this is because of the side view mirrors and AM is likely to fix this issue in the next model by moving them to the door (just like on Vanquish). It is very annoying.
Old Feb 24, 2016 | 07:28 AM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
British cars all have this issue haha, my lotus and aston have a tiny leak if i spray my pressure washer at the driver window
Old Feb 24, 2016 | 07:41 AM
Scotty4300's Avatar
Scotty4300 is infamous around these parts
Wind
My only problem has been my hat getting blown off above 180km/hr.
But I never drive with the roof closed!!
Old Feb 24, 2016 | 03:50 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
On the Porsche 991 there has been a solution. Check out the 991 forum. AWE has made some wind defusiers to eliminate the wind buffeting. Something like that may help on our Astons.
Old Feb 26, 2016 | 05:09 AM
cuddapah's Avatar
Here's the link .. https://www.6speedonline.com/forums/...-981-991s.html
I wonder if it will work for AMs.
su_maverick
May 15, 2019 04:13 PM
REKX
Feb 4, 2016 11:56 PM
mep1811
Cayenne 958
Feb 1, 2016 09:50 PM
