Adhesive Question....
Old Apr 17, 2016 | 08:02 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
The fuel filler door panel cover is attached to the hinge assembly for the fuel filler via an adhesive.
Does anyone know what type of adhesive is used?
I'm having a new fuel filler panel cover made (carbon fiber), and need to attach it to the hinge assembly prior to installation.
Thanks!!!
TAC
Old Apr 18, 2016 | 03:26 PM
Old Apr 18, 2016 | 09:23 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
If I were in your shoes, I'd use a bead of black RTV. It will hold well but is removable if needed.
Old Apr 18, 2016 | 11:42 PM
robertwroth's Avatar
robertwroth is infamous around these parts
Structural adhesive
If you want it to be permanently attached to the door you can use Urethane structural Adhesive (not sure if I can post a link - sear for Norton SpeedGrip on Amazon). I've used this to bond panels/body work and it's quite strong and permanent as an automotive adhesive.
terminal_ac
Sep 14, 2016 01:27 PM
CTDan
Apr 14, 2016 01:48 PM
