spacers to suit V8V
Old Dec 26, 2023 | 05:13 PM
  #31
Pangerz's Avatar
5 Year Member
Pangerz is infamous around these parts
Originally Posted by Zettinger
Congratulations to your new car!!!
Front: H&R TRAK Spacers (2265681CR)
11mm for the front come with own nuts to replace the originals.
Bolt Pattern: 5/114.3
Bolt/Stud: Stud
Center Bore: 68.1
Thread Type: 14x2.0
Width: 11mm
Rear: H&R TRAK+ Wheel Spacer DRM Style 4665681
23mm for the rear have studs on the spacer (DRM) to use OEM nuts.
Bolt/Stud: Stud
Center Bore: 68.1
Thread Type: 14x2.0
Width: 23mm
Why I went for H&R Spacers?
- I didn't want to replace or modify the existing OEM studs.
- H&R spacer are approved by the German TÜV what means they are tested for safety.
- Getting the certification for TÜV is most likely the most cost for spacer production. H&R were significant cheaper than the competition.
- 23 mm is 100% flush with the fender in the rear.
- 15 would have been better on the front for optic but as mentioned above, I rather keep the OEM studs.
Here a recent picture with spacers:
Hey guys,
Just had some custom spacers made to these specs. There are holes in the back of the OEM wheels but they **JUST** don't allow the original hub bolts to slide into them. Did you guys end up shaving down the original bolts (I don't really want to do that)?
I'm thinking of enlarging the existing holes (where the red arrow is in attached pic). Have any of you done this and if so how did you do it??
Thanks!
Thanks!
Old Dec 26, 2023 | 05:31 PM
  #32
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
See https://www.6speedonline.com/forums/...3mm-setup.html
Pretty sure I wouldn't try drilling out my wheels like that though.
Old Dec 26, 2023 | 05:58 PM
  #33
Pangerz's Avatar
5 Year Member
I'm down to give it a try. Any ideas on the best way? Dremel?
The guy in that thread drilled it out but he had a proper drill press
JustDJR
Aug 11, 2016 12:01 PM
Falcondrivr
Apr 5, 2016 07:19 AM
rdsrllc
Bentley
Apr 2, 2016 03:01 AM
semicycler
Mar 21, 2016 02:50 PM
semicycler
Mar 21, 2016 02:33 PM
