It's Alive!
Old Aug 29, 2016 | 07:45 AM
pikajew's Avatar
pikajew is infamous around these parts
Originally Posted by Prefurbia
A few things you might consider:
The picture below is of the seats I had done using Aston's modern stitching pattern but with larger diamonds and internal to the seat. I wanted actual Aston leather, but the dealer said their supplier could match the color and their leather would wear better - while it did match for a while it quickly faded to another hue and after just a month showed signs of premature wear. I traded the car for a 15 GT, but had I kept it they would have refinished the leather. So be aware and keep with Aston's supplier.
The next is of a clear paneled hood I had done with back lighting to show off the detailed Chevy 383. Similar to that which you did elsewhere.
I also had gills made (the 928's are nicknamed the shark) and had a rear view camera placed in the upper portion of the back gill on both sides... with screens installed into the dash panel. Color was the BMW Mini Orange.
Lastly I did not want a liberty walk look and instead fender widening that would look mild and factory. They actually did about 20 radial cuts in the fender, pulled it out about 2 inches, then filled and reshaped to get the car wider but in a very stealth way. The fuel cap is a Mustang part. The car won People's Choice Award at a Car Craft Summer National.
Old Aug 29, 2016 | 09:07 AM
pikajew's Avatar
Originally Posted by pikajew
As promised...
Old Aug 29, 2016 | 03:16 PM
rohnin's Avatar
rohnin is infamous around these parts
I might have to go back to AMB and get those wings.. how hard is it to remove the original ones safely?
Old Aug 29, 2016 | 05:26 PM
pikajew's Avatar
I used a hair dryer to soften the glue, then used dental floss to slowly work the badge off followed by "goo gone" (or any de-tarring product) to remove the residue.
Old Aug 29, 2016 | 08:31 PM
superuser's Avatar
superuser is infamous around these parts
Be careful with goo gone, make sure you get the automotive version. The regular stuff can hurt your clear coat.
Old Aug 29, 2016 | 09:27 PM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Those badges are sexy, any ball range of the wallet damage?
Old Aug 30, 2016 | 06:16 AM
mkzhang's Avatar
Wow thanks! That's a lot lower than what I was bracing for
Old Aug 30, 2016 | 05:34 PM
Vikram's Avatar
Vikram is infamous around these parts
This is best looking V8 Mods,Congratulations,Totally worth it..
Old Aug 30, 2016 | 11:13 PM
pikajew's Avatar
From your lips to god's ears! We shall see. On the bright side, if it ends up being too much, I won't have any problems finding someone in Los Angeles to buy it!
Old Sep 2, 2016 | 05:15 PM
pikajew's Avatar
Just got a sneak peak of the smoked side markers (Oracle built a custom LED Amber circuit board inside instead of the single wedge bulb) and painted center caps (to match the gold emblems - I'll be overlaying a AM wings logo on top of the gold and then clear coating).
Old Sep 7, 2016 | 12:51 AM
pikajew's Avatar
Many thanks to Tony Hall for the polished brass/black text sill plates (pic below) to match the overall black/gold theme of my project V8V Roadster. These are going on carbon fiber door sills and Tony even found me black screws for the sill plates and polished brass bolts for the carbon fiber door sills.
I'm also going to try gold plated sill plates with black etching... (Pics to follow.)
Old Sep 17, 2016 | 10:53 PM
pikajew's Avatar
Oracle finally got the headlight projectors back from laser etching. Soon the headlight mods will be complete!
Old Sep 22, 2016 | 03:32 PM
pikajew's Avatar
Headlights are 99% completed.
Old Sep 27, 2016 | 04:19 PM
pikajew's Avatar
Interior gold plating looking good so far. Big thanks to AMBits and Mike at Bamford Rose for sending the electroplater the housings for my glass switch conversion and glass key ECU conversion!
Old Sep 27, 2016 | 04:20 PM
telum01's Avatar
wow those look like they came out really well!
