DB9 -- separating lens from tail light - any info?
Old Sep 25, 2016 | 05:49 PM
K9COP's Avatar
K9COP is infamous around these parts
Hi guys, I have the usual condensation related failure in one of my clear tail lights. I may have an opportunity to remake the LED boards that usually fail.
Sorry for new thread but I can't find any info on search.
Is it possible to get the lenses off the light housings without destroying them?
I searched and found the 'tail light condensation' thread, but apart from sawing up the assembly, it didn't offer much on getting the lens off.
Does anyone have any pics of the BACK (inside) of the lens off the assembly or any other pics/advice (apart from 'don't bother!) please? Is there more to it than carefully cut seal around the edge and release clips? Does anything come off with the lens?
Thanks, K9
Old Sep 25, 2016 | 06:21 PM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
This is the only thread I can recall that remotely touches on it
https://www.6speedonline.com/forums/...ail-light.html
Old Sep 25, 2016 | 07:25 PM
K9COP's Avatar
Thanks mate, I saw that one, but it misses out on the crucial piece of info about how to get the lens off. Mine is most of the way off, but it feels like something is still attached about half way along, so I don't want to force it...
K9
Old Sep 26, 2016 | 01:05 AM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
K9
MKZhang posted a process for removing the lens for headlights from the base frame. He said put in cardboard box, then have small opening in the top and use a hairdryer. That amount of heat softens the glue enough to peel the lens off. IF this is the issue there is your fix.
IF not then all taillights are likely the same for the AMs. Red or White, so just see if someone has a pic of one taken apart somewhere and see what might be holding it up. Not sure how to reseal, but I bet if you reverse the process of heating it up, then sticking it back on and letting dry you might be good.
PhastAM
Mar 27, 2018 03:40 PM
Rguy
Dec 31, 2016 06:05 AM
drspeed
Sep 21, 2016 11:43 AM
zenzi
Sep 4, 2016 02:17 PM
ECS Tuning - BMW
Sep 1, 2016 03:04 PM
