Start up after sitting
Old Oct 2, 2016 | 09:14 PM
seastu's Avatar
seastu is infamous around these parts
Just wondering how many days folks let their Aston sit before using the hold the accelerator to the floor method and wait for the oil pressure light to go out procedure. It's an easy process and seems to make sense when the car sits for a week or so.
Old Oct 3, 2016 | 05:00 AM
handyman2009's Avatar
Veteran: Canadian Forces
For me I was thinking a few weeks but than again it never sits that long in my garage...:-)
Old Oct 3, 2016 | 06:40 AM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
I do it if its been sitting for more than 1 month, so pretty much after winter or during months where I'm busy and its raining a lot
Old Oct 3, 2016 | 07:27 AM
embdenb's Avatar
For me it would probably be a couple of months. Engine oils today are so much better than they were years ago.
Old Oct 3, 2016 | 05:16 PM
deckman's Avatar
I do it the first time I start the car the day I drive it. Every single first start of the day. I got used to doing that with my Porsche, and it was not as simple with that car.
Old Oct 3, 2016 | 07:14 PM
Dalecannavan's Avatar
5 Year Member
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
Can someone expand on this as its new to me and I don't understand it? Thanks.
Old Oct 3, 2016 | 08:37 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
No lubrication (oil pressure), on a cold start-up, may increase wear on the engine internals after the vehicle has sat for an "extended" period of time.
Cranking the engine with the gas pedal pushed to the floor allows the oil pressure to build up to "normal" pressures allowing lubrication to the engine internals before starting, thus theoretically reducing engine wear on the subsequent cold start-up.
I personally, don't use the technique unless I haven't driven the car for months on end (not likely in CA).
It boils down on how often you drive your car...
Anyhow, as posted earlier, modern lubricants are quite superior to those used years ago...
YMMV.
Old Oct 4, 2016 | 06:40 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
This only works on cars with a Ford ECU. Later cars will fire up at full throttle.
Old Oct 4, 2016 | 01:14 PM
deckman's Avatar
Mine's a 2013. How much later than that does it stop working?
My opinion is it certainly won't hurt your engine by doing this at each cold start, and it may reduce wear. So why not do it each time?
Old Oct 4, 2016 | 08:35 PM
DonL's Avatar
Check your owners manual...
You run the risk of premature replacement of your starter motor.
Cranking to build oil pressure is about 10-20 times longer than needed to start the engine.
Again, to each his own...
Old Oct 5, 2016 | 01:10 PM
deckman's Avatar
My owners manual is for my 2013. I already know it works for that MY. YVR said it doesn't work on later models so I was wondering when they stopped it.
Old Oct 5, 2016 | 02:11 PM
yvr's Avatar
yvr
The V12 cars with variable valve timing switched to a Bosch ECU, so DB9.2, V12VS, Vanquish.
Old Oct 5, 2016 | 06:14 PM
larryg's Avatar
larryg is infamous around these parts
Certainly works on my 2014 V8V
Old Oct 6, 2016 | 07:14 AM
DonL's Avatar
Thanks for the clarification...
Old Oct 6, 2016 | 07:36 AM
deckman's Avatar
^^ +1
