How do you close this clamp?
Old Oct 6, 2016 | 02:43 PM
LIDB9's Avatar
LIDB9 is infamous around these parts
I have 2007 DB9 had trouble reinstalling aoirbox so took loosened clamp from outlet tube to give more manuevrability,seemed easy enough just inserted screwdriver under clasp and came apart,not so easy closing it anyone run into this problem,basically clasp has to fit over bar and its in a crappy location,thx
Old Oct 6, 2016 | 04:11 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
I usually use channel lock pliers and squeeze it back together. Just grasp the 2 round pegs on either side and squeeze till it is closed.
Old Oct 6, 2016 | 04:15 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
You need a right kids of tool then it takes like a second.
I don't know what's it called or wher I bought it but here is the picture.
Old Oct 8, 2016 | 12:12 PM
LIDB9's Avatar
I s there any manufacturer on that tool thx
Old Oct 8, 2016 | 12:41 PM
Ok I found it if you search "long click clamp" on eBay you will find it for about $20. You could check harbor freight too.
Old Oct 8, 2016 | 12:54 PM
LIDB9's Avatar
thanks so much just ordered one
Old Oct 8, 2016 | 01:33 PM
It has rotating head with each head has uneven ends one large and one small. If I remember correctly you need to align those rotating heads such that on one side you use larger portion and on other side you use smaller part.
bebeqq1231
Feb 21, 2017 12:07 PM
Lisa@Borla
Oct 6, 2016 11:09 AM
zuman
Oct 6, 2016 08:53 AM
LIDB9
Oct 5, 2016 07:34 AM
riozilla
Oct 2, 2016 07:37 PM
