DB9 Front grille removal
Old 10-06-2016, 09:09 PM
randyb's Avatar
randyb will become famous soon enoughrandyb will become famous soon enough
How do you remove the darn thing, looks like the slats can be removed from the mount without the need to remove the bumper, but I also know looks can be deceiving.
So do you have to remove the bumper?
Just need the slats out so I can paint them.
Old 10-06-2016, 10:48 PM
drivergmx's Avatar
drivergmx is a jewel in the roughdrivergmx is a jewel in the roughdrivergmx is a jewel in the rough
The bumper must come off if you are replacing the frame (item 2) however, if you are only planning to remove the slats (item 1), you can access them by removing the radiator cover and separating the slats from the frame by removing the 7mm nuts from the inside...
Old 10-07-2016, 07:53 AM
randyb's Avatar
Perfect, thanks
superslow
05-17-2018 03:28 PM
hkg1997
10-06-2016 09:03 AM
Gberg996
10-06-2016 07:14 AM
Jako
10-06-2016 06:26 AM
NocheEnParis
10-05-2016 08:07 AM
Quick Reply: DB9 Front grille removal
