Door remotes
Old Dec 5, 2016 | 03:58 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Door remotes
07 Vantage and I only got one remote with the car . Theres a good used one on flea bay . Can it be easily reprogrammed to my car or is it a trip to the dealer only job ?
Old Dec 5, 2016 | 06:10 PM
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
I believe it's a dealer job. Happy to be corrected, though!
Old Dec 5, 2016 | 06:49 PM
handyman2009's Avatar
Veteran: Canadian Forces
Rich, you are correct a trip to the dealer with the car and new remote is needed as I got it done this summer. Be careful about buying them on flea bay as you need a code that they usually don't have with them and if you don't provide the dealer the code they can't help you. Irish07 had a post on this I believe... I bought mine (plastic FOB) from the dealer and got it programed along with the metal key to unlock the doors if the battery goes dead, they have to order that key directly from AM in the UK which comes cut for the car.
Old Dec 5, 2016 | 09:24 PM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
fleabay ones will almost never have the code. i looked into this rather in depth. your cheapest bet will be ambits (and hope they still sell a single fob as opposed in pairs only). then take that with the code they provide to your dealer for matching, you'll get charged for 1 hr of labor.
Old Dec 6, 2016 | 04:25 AM
And also check with your dealer to see if they will program FOB that you bring in... I didn't take a chance and bought mine from Decarie Motors in Montreal and they programed it.
Old Dec 6, 2016 | 02:03 PM
embdenb's Avatar
One hour labor is usually $150.00
Old Dec 6, 2016 | 02:14 PM
Vantagelvr's Avatar
I have asked the seller if they have the code for the remote ............no answer as yet and its been 24hrs .
Old Dec 6, 2016 | 11:01 PM
yeah no kidding, mine was $160.
Old Dec 7, 2016 | 05:58 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
I purchased a blank un cut key and remote from Aston Bits, it came with codes, dealer did the program (charged 1 hour @ Aston rates) had the key cut at a key cutting place no issues. Not sure I would risk ordering a pre cut key even from Aston via the Vin number, most key cutting services can copy it over without a problem.
Talking to them when they paired the car with the remotes and new key transponder they said they simply add the new codes into the cars data base, max 4 units can be in the car program then they deliete if you need a new one.
Two weeks later I found the original so about 3 grand down I now have three remotes and keys
Old Dec 7, 2016 | 11:26 AM
In my case I didn't have an original Metal key to copy so the only way to get one was through AM using my VIN.
Old Dec 9, 2016 | 04:39 PM
Vantagelvr's Avatar
Suprise.........I didnt get an answer about my question to the seller for the code for the remote so safe to say they dont have it so I wont be dropping the 150$US for it anytime soon .
Old Dec 9, 2016 | 06:36 PM
I was charged $380 for the FOB + $77.50 (1/2 hour) to program it all + tax
Old Dec 10, 2016 | 05:30 AM
Vantagelvr's Avatar
Im not going to be rushing to the dealer to pay $400 for a 59.95$ Volvo part with a fancy bit of leather on it !!!!
Old Feb 21, 2017 | 08:34 AM
patrija's Avatar
patrija is infamous around these parts
Resurrecting an old thread. I bought a new AM key set (crystal + plastic) with the codes and took it to my local dealer for programming. They said the plastic key works perfect (start and unlock), but that the crystal key will start but not lock/unlock. Any advice before I pick the car up?
Old Feb 21, 2017 | 08:36 AM
electronaut's Avatar
electronaut is infamous around these parts
Who did you buy the crystal key from? Either the dealer you took it to for programming hasn't programmed it correctly, or the key is defective.
