Replacement 'emergency' Key
SubscribeWhen purchased new, Astons come with a metal 'emergency' key that can be used to unlock the door if the ECU or valet key does not work because of a dead battery. My pre-owned 09 Vantage did not come with this key. I am told a replacement can be obtained from the original dealer and assume the key has to be cut to specifically fit my car. The original dealer, Ray Catena Aston Martin in New Jersey, is no longer in business as an Aston dealer so I have no way of obtaining any original records relating to the car.
Has anyone had any experience in obtaining a replacement 'emergency' key?
If I can't obtain a new metal key - and the car is locked with a dead battery - how would I jump start it?
Call your nearest dealer.
I got one done last year and the Dealer in Montreal told me that they order the key directly from the Aston Martin in the UK. The only needed my VIN and confirmation that the car was actually mine
They said it was laser cut or something like that, good thing I did as 5 wks after I bought it the battery was dead and needed the key to get in
They said it was laser cut or something like that, good thing I did as 5 wks after I bought it the battery was dead and needed the key to get inIt is not a given that the key code will be on file for your VIN. If the delivering dealership did their job, it might be.
In my case, it was not.
If you do not have the door key and the battery dies, you'd have to jump it from underneath.
My car didn't come from the dealership in Montreal... AM Factory will have the Key Code
The emergency key is not used to start the car. It is inserted in the door key slot to open the door.
I will contact my current dealer to see if they can help me out getting a new key.
Quote:
Haven't had to do it on the AM, yet, but generally you just have to find the starter, connect hot jumper lead to the starter power wire, ground the other starter lead, unlock car with remote.Originally Posted by messar
Mathman85 - do you have more detail on jumping the car from underneath?
I confirmed the above information and ordered a new key from Miller Motorcars today. $300. I have yet to establish a connection with a dealer here in the Midwest, so only Miller can confirm my ownership. Which I'm fine with and just glad to be getting this done.
Regards,
Quote:
Jack the Vantage up high from the passenger front, put jack stands front and rear(keeps the car from falling on you). Remove the under trays and then the right front wheel and inner wheel lining. You now can reach in the front of the engine bay and attach the booster pack leads to the jump post attached to the front of the right strut tower.Originally Posted by messar
Once the booster pack is connected, you can then press the unlock button on your remote, put everything back before opening a door...or at least the wheel and rest the car on it's own weight. This avoids any chance of twisting the car, especially if no jack stands weren't used..
If this became a common problem I would attach a long starter like cable to the jump post and terminate it somewhere behind the air filter wheel lining panel so all that would be necessary to get power to the car was the removal of the front wheel.Originally Posted by irish07
Jack the Vantage up high from the passenger front, put jack stands front and rear(keeps the car from falling on you). Remove the under trays and then the right front wheel and inner wheel lining. You now can reach in the front of the engine bay and attach the booster pack leads to the jump post attached to the front of the right strut tower.Once the booster pack is connected, you can then press the unlock button on your remote, put everything back before opening a door...or at least the wheel and rest the car on it's own weight. This avoids any chance of twisting the car, especially if no jack stands weren't used..
