Code 1233 and Fuel Pump Driver Module
Old Jan 20, 2017 | 11:43 AM
  #46
Pigdog's Avatar
Pigdog is infamous around these parts
I just redid the voltage and resistance readings as well as a visible inspection of the wiring.
The voltages were as indicated before 5 volt, but I was misreading the meter on resistance. In addition I had the pins wrong on the bad side
So on the bad side Vref 300 Ohm
monitor 5.3 KOhm
pin 1-3 4.6 KOhm
good side 22 KOhm pins 1 and 3
4.6 KOhm 1to3
Old Jan 20, 2017 | 11:44 AM
  #47
Pigdog's Avatar
I will post a link to a google site with pictures
Old Jan 20, 2017 | 12:08 PM
  #48
Pigdog's Avatar
I also just tried the voltage readings at the bad sensor with the engine running and no change
https://goo.gl/photos/UDRL5F6p8aHokfqC9
Old Jan 20, 2017 | 12:25 PM
  #49
Pigdog's Avatar
I am hoping the wiring checks out tomorrow. Would/could a bad PCM give funny resistance readings? How often do PCM's fail. They are basicly solid state right?
To double check do you know what pins I need to check on the PCM relative to the FPS pins 1,2, and 3
Old Jan 20, 2017 | 12:46 PM
  #50
Pigdog's Avatar
When you say zapped .....is zapped permanent or could a reflash be performed. Could this be from storm damage or lighting?
Do PCM's wear or would a used one be as good as new one?
Old Jan 20, 2017 | 02:31 PM
  #51
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
How are you measuring resistance? Are you measuring from the pin on the sensor plug to the pin on the PCM plug? With the PCM unplugged? 22Kohms for a piece of wire is a lot. I would expect minimal resistance from the sensor plug to the PCM plug. I would expect infinite (not connected) between pins 1 & 3 with the PCM unplugged. With the PCM unplugged, if you see something other than infinite between any of the pins then there's a short somewhere.
Rereading through the thread there are two possibilities: 1) the sensor wire for bank B is somehow shorted or 2) The PCM is somehow internally shorted. Those are the only way I could see the PCM reading pressure without the sensor being connected. I'd try to somehow pop the pins out of the PCM plug for the sensor and see if it still reads 75 psi. If it does then you know the fault is within the PCM.
Old Jan 20, 2017 | 02:47 PM
  #52
Pigdog's Avatar
I have not removed the wheel yet to measure the wire resistance at the PCM...I am measuring the resistance on the wire connected to the PCM.
I figure if there is no resistance on the wire when I disconnect it from the PCM then it has to be the PCM.
I will try to remove this connection from the pcm...perhaps I can insulate the connection
Old Jan 20, 2017 | 04:58 PM
  #53
Pigdog's Avatar
Well now it gets fun....Went to start the car for diagnostics and it fired right up.
Old Jan 20, 2017 | 06:51 PM
  #54
Pigdog's Avatar
The engine is running on all 12 now....I backed out of the driveway and it died. Same pulled back in and restarted. Drove around the block died. Restarted drove a couple miles died..restarted. Now I cant get her to fail. Checked resistance and got same readings as before. Fuel pressure readings fine. 45 lbs
I got code 606 on both sides when she died and a 1798 can bus error.
PCM's have intermittent errors? Battery issues? Ghosts?
Old Jan 20, 2017 | 06:57 PM
  #55
Pigdog's Avatar
Test Drive
Old Jan 20, 2017 | 09:26 PM
  #56
Pigdog's Avatar
I am not sure .....now I have an intermittent problem. I have an appointment at the Aston Martin dealer in February. I think I might trailer the vehicle to Nashville to get the car scanned and the PCM's flashed.
The battery is an Interstate and is 2.5 years old but I have not had the car but for 7 month don't know what this battery went through and AM's are hard on battery. I may just replace it with a gel cell or high capacity battery
Old Jan 20, 2017 | 09:38 PM
  #57
Pigdog's Avatar
I dont think it is the wiring now. Because every time it would die I got a 606 code and it would always clear on a restart. If the problem wire was shorting the trouble would not go away on a restart.
If you have an electronic device that has a fault I would think it would be a good possibility it would clear itself upon restart.
Make sense?
Old Jan 21, 2017 | 07:22 AM
  #58
Pigdog's Avatar
Back to her old tricks again.....Damn
Old Jan 21, 2017 | 08:44 AM
  #59
Pigdog's Avatar
Couple of observations. Started this morning no problem. Cut the car off. Started not problem. Backed the car out put the car in drive went 15 feet Problem arises again.
Park the car. Now the car wont "reset". Come back an hour later starts and drives. I drive 2 miles problem again. Park the car now the car will restart
The car has never "reset" while driving....only upon restart. When the car also goes into fault it is like someone flipping a switch
Old Jan 21, 2017 | 09:40 AM
  #60
Pigdog's Avatar
other than voltage what do i do to check the battery?
