Ticking noise Vantage
Old Feb 27, 2017 | 07:42 AM
Zettinger's Avatar
Zettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of light
Hi,
my Vantage produces a strange and embarrassing ticking noise.
It sounds like a nail in the tire, depended on rotation speed and temperature.
I took the tires off and couldn't find any nail or visible issue.
My car was two weeks in for service and the dealer couldn't reproduce the issue. My guess is since it was colder the last few weeks and the ticking requires warm weather.
When I picked her up, it was gone on the 30 miles back but the Friday last week it came back.
Does anyone experienced the same issue?
I just took a video in the parking lot on the way to work.
Old Feb 27, 2017 | 07:50 AM
pikajew's Avatar
pikajew is infamous around these parts
Believe it or not, I have a similar issue but not nearly as pronounced.
Old Feb 27, 2017 | 08:01 AM
Zettinger's Avatar
I believe you!
What makes it even more strange, AM replaced parts for close to 3k preventive to eliminate the ticking when I told them about it.
My car still has the AM warranty and I rather have this done as long as the warranty is good.
Old Feb 27, 2017 | 08:30 AM
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
Does it do it in reverse, too?
Old Feb 27, 2017 | 08:36 AM
Zettinger's Avatar
I think yes and I heard it parking backwards in the garage but will check when I drive home.
Old Feb 27, 2017 | 09:03 AM
Ktw's Avatar
Ktw
Ktw is infamous around these parts
From the brief view of the rear wheel, it looks like it's spinning too fast to match up with the ticking noise. That should eliminate something in your tire or wheels. My first guess would be something to do with your belt.
Old Feb 27, 2017 | 09:16 AM
Zettinger's Avatar
Good thought but the ticking continues when I press the clutch in higher speeds and revs go to idle.
Also it disappears when I turn left and is louder turning right.
Old Feb 27, 2017 | 09:33 AM
Redpants's Avatar
Have you checked the CV boots?
Old Feb 27, 2017 | 09:35 AM
silver997's Avatar
silver997 is infamous around these parts
Wheel bearings?
Old Feb 27, 2017 | 10:50 AM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
this guy has a similar issue
says it was rear brake shoes
"Rear brake SHOES. Not 100% sure, but since your car has 4 wheel disc's - the rear emergency brake is a pair of brake shoes inside the rotor hat. The friction material delaminated from the shoe and the clicking & ticking was the material bouncing around inside the rotor hat. Remove the rear wheel, caliper and rotor (with e-brake OFF!) and take a look peek!"
Old Feb 27, 2017 | 11:27 AM
Redpants's Avatar
We don't have rear brake shoes. There's an extra brake caliper on each of the rear rotors. These are actuated by the handbrake. There aren't any brake shoes inside the rotor hats.
Old Feb 27, 2017 | 12:09 PM
skywagon's Avatar
skywagon is a jewel in the roughskywagon is a jewel in the roughskywagon is a jewel in the rough
I had a ticking noise coming from my left rear wheel a few months back. I would gently pull on the parking brake while moving slowly and it would stop. I adjusted the parking brake cables and the noise has not come back. The driver's side was looser than the passenger side. I am not quite sure how that was the cause but it has not come back.
Old Feb 27, 2017 | 12:17 PM
Zettinger's Avatar
Nope but the dealer did replace them last week when they tried to fix the problem.
Originally Posted by silver997
Wheel bearings?
That is my guess and what I communicated with the dealer, it is also hard to identify where the noise is coming from. The dealer replaced the rear bearing but I guess it is the front wheel bearing.
https://www.youtube.com/watch?v=2ZwOvNaMxNY
Good guess but we don't have brake shoes as Redpants mentioned.
Old Feb 27, 2017 | 12:19 PM
Zettinger's Avatar
I tried the hand brake and the noise did not change.
Old Feb 27, 2017 | 03:14 PM
handyman2009's Avatar
Veteran: Canadian Forces
Did you have a look at your front caliper, the spring plate that is held by the 2 pin. Mine was making similar noise when turning and it was that little plate that wasn't sitting properly and was touching the disc. If you take them out you will know right away as you should notice the rubbing on those spring plate.
