How long can the vantage stand unused?
Old Jul 27, 2017 | 11:35 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
I have been called out (duty) and may have to leave on short notice.
Can I leave my beloved Aston for 5 months with no attention, I was thinking of just removing the positive battery terminal?
It stands in a garage and will be covered.
Advise appreciated
Old Jul 27, 2017 | 11:57 AM
MikeR397's Avatar
MikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant futureMikeR397 has a brilliant future
I left my Ferrari and other four cars for 5 months when my family moved to Maui in between moves. Trickled charger, stabile, and carpet under the tires, zero issues. Don't worry about it, and thanks for your service!
Old Jul 27, 2017 | 11:58 AM
EuroKip's Avatar
EuroKip is infamous around these parts
Battery tender
Old Jul 27, 2017 | 12:04 PM
Thanks for comments, my concern with the battery tender is that if it gets hot or malfunctioned during my absence I would not know and would hate to get home home to a pile of ash?
Could I not just leave battery disconnected?
Old Jul 27, 2017 | 12:09 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Dont
Don't forget to put rat or mouse killer around the car. Mice love to chew on wire and such.
Old Jul 27, 2017 | 12:12 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
LOL, not likely, but yes you can leave it disconnected for 5 months.
If you have jack stands, I would leave car on stands as to prevent flat spots on the tires, you do not have too, it is something I like to do.
Old Jul 27, 2017 | 01:12 PM
larryg's Avatar
larryg is infamous around these parts
Inflate the tires to 50 psi
Trickle charger or remove the negative battery terminal
Ctek chargers are remarkably good-I have never experienced a problem with them
Old Jul 27, 2017 | 01:22 PM
Good call on pumping types hard.
Thanks for this tip any reason why the negative terminal?
Old Jul 27, 2017 | 02:12 PM
Rwp137's Avatar
Rwp137 is infamous around these parts
All of my cars sit on battery tenders. They work amazing. Thank you for your service...
Old Jul 27, 2017 | 02:32 PM
rohnin's Avatar
rohnin is infamous around these parts
Full tank of gas
Old Jul 27, 2017 | 03:17 PM
embdenb's Avatar
It really does not matter which battery post you disconnect. The reason the negative terminal is always suggested, Is because if you try to disconnect the positive terminal first there is the possibility that the wrench might come on contact with the cars body resulting in a short. ( nothing good happens at that point )
Old Jul 27, 2017 | 07:00 PM
Jagman70's Avatar
Jagman70 is infamous around these parts
All good advice. This no different than putting a car up for winter storage.
C-tek chargers are very reliable. Have used them for winter storage on several cars. Disconnecting the battery may require a number of codes to be reset later.
Fill the gas tank and add Stabil to the gas to keep it fresh. Add a few extra pounds of pressure to the tires.
If mice are an issue, I recommend buying a storage bag to seal a the entire car. You can also add desiccant (moisture absorbing bags) to keep the car dry.
Hope this helps.
Old Jul 27, 2017 | 08:02 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
+1 on the Moisture absorbing bag or like kind stuff (I use the prepackaged plastic cups of Damp Rid with carbon). Put one in the trunk as well. And yes a ctek/Aston battery tender with the tender unit placed outside the car. When restarting remember to follow the return to service " after storage procedures". Thanks for your service!
Old Jul 27, 2017 | 10:21 PM
sanjay's Avatar
sanjay is a jewel in the roughsanjay is a jewel in the roughsanjay is a jewel in the rough
i've always parked my cars for 5 or so months every year.
i add stabil and top up -- and plug in my battery tender
never any issues.
Old Jul 28, 2017 | 05:45 AM
larryg's Avatar
Gas stabilizer, overinflate the tires, top up the tank and connect your Ctek.
It is that simple
