Special Vehicle Care 101: General Cleaning
I buy either Sonax Full Effect of P21S in 5L containers and switch brands when the last one is near the end. I spray the next wheel with the cleaner right before I do the final rinse on the previous wheel. That way it's on there maybe 20 seconds before I start scrubbing the wheel.
Coat your wheels and never use a wheel cleaner again. Only soap and water and the wheels will look better than ever before. Contact me if you want to do this and I will walk you through the process buddy
Master Blaster blows (no pun intended) compared to high capacity air compressor. Not worth the investment IF you have a 175 psi air compressor. Takes too long to completely evacuate water from crevices.
Pun should be intended. I have to wear ear plugs when blowing out the crevices with the master blaster, it blows so hard! Every car I own can be dried in under 5 mins. Not sure what too long is, but 5 mins per car with a safe nozzle (rubber) seems reasonable. The fact that it rolls on the ground blowing heated and filtered air seems a bonus 🤘🏻
You can put a sealant or wax on top of it just like the paint, i would hand apply unless the buffer you are using has a light touch. REMEMBER with the buffer you will get wax into the edges of the PPF if there are any. A way to clean those us use a spray wax and a MF towel on those edges. IF you vehicle has Ceramic coatings DO NOT use a spray wax, they make sprays for coatings which is what you should be using.
Let mw know if there are any further questions
