2009 V8V and CTEK Mus 4.3 settings quesiton
Old Mar 4, 2018 | 02:54 PM
rocketboots999's Avatar
rocketboots999 is infamous around these parts
Originally Posted by Denver V8V
...Next question, replacement battery, standard or AGM? Anyone who can share their experience?
Last year, I fitted an AutoCraft Platinum AGM Battery, Group Size H8, 850 CCA that comes with a 3 year warranty. It's been connected to my CTEK on the Snowflake setting during the Winter hibernation. I took the car out for a run twice last week. So far, so good.
Old Mar 6, 2018 | 01:23 PM
Denver V8V's Avatar
Denver V8V is infamous around these parts
Just replaced the battery with a Bosch AGM and now my window works but top doesn't. I had a local shop with AM experience replace it and to get the passenger side window open they reset the fault codes.
I appreciate the feedback on the battery. Hard to believe it was the original factory one installed in '09.
Last time I dropped the top was January 1, 2018. Not sure what's causing this but I will search this site for related issues and see what happens.
Old Mar 6, 2018 | 04:33 PM
After I replaced my flat battery, I had the usual seat and window issues until I reset them. My top also got itself out of sync closing on itself the first time and jamming up. Major panic, but no damage and once I untangled the top from the tonneau panel, all has worked perfectly since. Probably jinxing myself with that last comment!
Old Mar 7, 2018 | 12:47 PM
Denver V8V's Avatar
On another forum I read where one individual with similar issue held the top operation button down in the close position and it reset the top. I did that and now it works.
Wow, who knew?
Old Nov 20, 2018 | 02:19 PM
Denver V8V's Avatar
My passenger window won't drop to allow the door to open, how do you reset the window?
997ttt
May 31, 2008 09:45 PM
jkb
Wheels/Tires
May 12, 2007 08:22 PM
