Need Help on Rapide Tail Light Replacement
Old Mar 17, 2018 | 08:15 AM
LloydB3's Avatar
LloydB3 is infamous around these parts
I am trying to replace the left hand side tail light in my 2010 Rapide and 2 of the 3 nuts are visible and the third appears to be under the trim next to the trunk opening. I have no idea how to remove this trim. There are the round metal clips which appear to hold up the trim, but I don't know if they pop out or screw out. In addition, it appears that the trim also goes under the aluminum plate for the trunk latch. This aluminum trim may also need to be removed and I have no idea how to remove it either. Any suggestions would be appreciated. Thank you, Lloyd
Old Mar 17, 2018 | 11:47 AM
LloydB3's Avatar
I figured it out. Just had to pull back the carpet from the moulding around trunk opening and remove one screw next to moulding and was able to get carpet back far enough to access the bolt. There were no clips involved.
svre46
11
Jul 13, 2017 07:23 AM
lamborarri
Oct 7, 2016 04:03 PM
gircal
Dec 30, 2012 09:06 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
