Acc Socket Dead
Old Apr 7, 2018 | 01:09 PM
MRCW's Avatar
Acc Socket Dead
The ACC Socket in my 2009 V8V is dead. It is the one in the main cubby with the aux and ipod connectors...The one in the little ash tray area works, as does the one in the boot area.
i checked fuse F55 in the cabin fuse box and the F2 one in the rear fuse box...
Any thoughts?
Old Apr 7, 2018 | 01:14 PM
handyman2009's Avatar
Veteran: Canadian Forces
I would look under the console to see if one of the wire got pinch and possibly cut or just unplugged
Old Apr 7, 2018 | 01:23 PM
MRCW's Avatar
Acc Socket Dead SOLVED
Solved the problem, just in case others have this problem...In Owner's Manual Fuse F63 says "Not Available"
However in Workshop manual Circuit Diagrams, Page 9 of 17, "Driver Operated Auxilary Systems" Fuse F63 is called out for the "Socket Front Cubby Box." Sure enough the fuse was blown!
Old Apr 7, 2018 | 03:02 PM
Batman-76's Avatar
Batman-76 has a spectacular aura aboutBatman-76 has a spectacular aura aboutBatman-76 has a spectacular aura about
I don't see anything that leaves that high
Trunk box goes to 22
Under Bonnet box goes to: 34
I have the same issue with my aux plug and got excited about potential fix :-/
Old Apr 7, 2018 | 03:26 PM
MRCW's Avatar
Its the fuse box in the cabin under the carpet on the right side floor pg 11.41 in manual
Old Apr 7, 2018 | 04:44 PM
Batman-76's Avatar
Hmm
Nope. Mine only shows under bonnet and boot
I'm looking at at 2012 Vantage S
Old Apr 7, 2018 | 08:30 PM
J doubleU's Avatar
Later models do not show the cabin fusebox in the owners book. You need to remove the aluminum panel under the passenger carpet footwell 7 screws 30torx.
Old Apr 7, 2018 | 08:45 PM
Batman-76's Avatar
Thanks.... found the panel.
Fuse tested good :-(
Looks like I'll be disassembling the armrest tomorrow
Old Apr 8, 2018 | 01:06 PM
Batman-76's Avatar
The clip wasn't plugged in :-/
I recently had the Bluetooth module upgraded, along with other minor service details... guess they forgot to reclip the accessory plug
Old Apr 8, 2018 | 01:18 PM
MRCW's Avatar
glad you got it working!
7and911
Jun 6, 2014 01:57 PM
JPanamera
Mar 11, 2005 11:48 AM
