so I bought a 2010 v8 vantage 4.7 l stick with 5500 miles; now what?
Old Apr 16, 2018 | 10:51 PM
buckarooboy's Avatar
5 Year Member
buckarooboy is infamous around these parts
just purchased a 2010 v8 vantage stick 4.7 l with 9400 km on it (5500 miles). It was serviced through its life by the dealer. Last serviced in Oct 2016 when it was at 8900 km. So it has had 500 km put on it since its last service which was about 1 1/2 years ago. Other than an oil change what else should i be looking at here? I am wondering about complete fluid change like brakes, transmission, rad, diff? Any thoughts would be appreciated. It appears that the service interval based on mileage does not apply here but rather the vehicles age should be the primary factor in what maintenance is complete
Old Apr 16, 2018 | 10:54 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
The fluids have a time/mileage schedule. Follow that if you have the full service records. Do you have your owner's manual?
Old Apr 17, 2018 | 05:11 AM
handyman2009's Avatar
Veteran: Canadian Forces
Beside fluid replacement, Drive the beast and enjoy it
Old Apr 17, 2018 | 07:43 AM
Ron Avery's Avatar
Ron Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to behold
Sounds like a cool Vantage. Good choice on the the transmission.
I would call your local dealer. We also need photos.
Ron
Old Apr 17, 2018 | 09:06 AM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
in addition to getting all the fluids changed, you will probably need new tires and maybe wiper blades, I hear the Michelin P4S's are the beez kneez
Old Apr 17, 2018 | 10:22 AM
Zettinger's Avatar
Zettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of light
congrats!!!
Sounds like a great car and perfect choice on transmission.
+1 on the wiper blades.
My, November 2009, Vantage came with 8900 miles as well, tires were replaced right before I bought her but the wiper blades were crap and came apart shortly after purchase.
Old Apr 17, 2018 | 11:18 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Aston dealers normally do the brake fluid with the oil change annually. How do you rotors and pads look? There are air & cabin filters that may need replacing. Batteries on the remotes. Do you have the metal key?
Old Apr 17, 2018 | 09:10 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Do an oil change and drive it and enjoy.
Old Apr 18, 2018 | 03:27 PM
veijones's Avatar
veijones is infamous around these parts
Congrats!! Your job now is to DRIVE IT A LOT! I've got 105K on my '06 V8V and it doesn't feel much different than when it was new - maybe better actually! Keep the leather treated so it doesn't dry out ..
Old Apr 18, 2018 | 05:46 PM
Yorick's Avatar
Yorick is infamous around these parts
I bought my 2009 Vantage with a MT 5 years ago @ 7000 miles, it's your car's one year older sister. I found that the following 3 things were the best changes, IMHO, that I made on my car.
Change the brake pads to Porterfields at your earliest convenience. You will appreciate how little brake dust they produce compared to the stock ones.
The transaxle consists of the transmission and differential in one casing and they share the same oil supply. Do not use a GL-5 transaxle oil, it tends to erode and shorten the synchro ring lifespans. Use only GL-4 gear oil.
If the original tires are still on the car it would make them almost 10 years old. There is probably tread remaining but the rubber compound has aged and become too hard for optimum traction. Do not replace with the original Bridgestone 050A. The Michelin Pilot 4S is one of the hottest tires on the market right now, you'll love them, huge improvement over those Bridgestones. Put them on last year, love them.
Hope that helps at least a little. The last and best step is to now go and enjoy your four-wheeled masterpiece. And the faster you go the better it will feel. Prepare to get too many speeding tickets.
Old Apr 18, 2018 | 10:09 PM
5 Year Member
thanks for the input
Old Apr 18, 2018 | 10:11 PM
5 Year Member
again thanks for the input. I am taking it to the dealer to go over. they have the service records from day 1 and told me they can assess the car and bring it up to date
Old Apr 19, 2018 | 08:48 AM
5 Year Member
Might as well install some VAP decats if they are putting on the lift.
Old Apr 19, 2018 | 05:31 PM
007V8Vantage's Avatar
007V8Vantage is a glorious beacon of light007V8Vantage is a glorious beacon of light007V8Vantage is a glorious beacon of light007V8Vantage is a glorious beacon of light007V8Vantage is a glorious beacon of light
Thumbs up Congrats on the purchase...
Sounds like you made a nice choice.
I'm looking forward to seeing it.
What colours did you go with?
Old Apr 19, 2018 | 07:55 PM
5 Year Member
aston 2010 6 speed pics
