Things I have learned 3rd day into owning the car
thanks for the tip. but how do i turn the sat nav off. that's what i can't figure out. i can press the NAV button next to the joy stick, but that doesn't turn it off. do i need to use my hand and manually fold the display back down?
On mine, if you press and hold the NAV button for ~3 seconds, it will turn itself off and fold down; press NAV again to bring it back. As previously noted, it will store the current state when you turn off the ignition.
instead of creating a separate intro thread, i am just going to combine it with this thread to avoid clogging up space.
went out and took some pictures today.
added them to the original post.
so i learned today that the Reverse gear plays trick on you.
in the past couple times i noticed if i give it a lot of gas while backing up and hit the brakes, the car has the tendency to want to stall. today in the parking lot at the gym i was in a hurry to pull out of a space because someone wants to pull in, so i gave it quite a bit of gas backing out, and boom, the car stalled for the first time on me. but i noticed that if i just leave the gas pedal untouched, and just let it coast in reverse it actually makes it out smoother.
complicated English girl she is. lol
Reverse gear is really tall - it's closer to 2nd than it is to 1st. The clutch is also pretty grabby. Let the clutch do the work, it'll help prevent you from burning it up by over-gassing (a leading cause of clutches going bad, especially when reversing uphill). True for starting out in 1st as well.
alexmadison
Oct 28, 2008 07:57 AM
