Emissions Service check engine light
Old May 1, 2018 | 04:32 PM
Z71TahoeEX's Avatar
Z71TahoeEX is infamous around these parts
The check engine light just came on and the screen is says my “Emission system service required”. Any ideas on what this is?
Old May 1, 2018 | 04:43 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
It's usually the gas cap either leaking or just wasn't tightened to click [yup, took mine in and he tightened the cap, and I felt stupid], but can also be O2 sensors IIRC.
Old May 1, 2018 | 11:12 PM
Logannz's Avatar
Logannz is infamous around these parts
Use a cheap ODB-2 scanner to check, its quite likely to show an EGR valve error. If so it's likely to be the DPFE sensor which is part of the valve. I'm writing up a post on that subject shortly in fact.
Old May 2, 2018 | 04:27 AM
Z71TahoeEX's Avatar
Where would I get one of those?
Old May 2, 2018 | 05:40 AM
Z71TahoeEX's Avatar
Ok so excuse my ignorance on this but where do I hook this up? And how do I know what the code means? I’ve never really done anything on my own car and I’m out of town at a place where there’s no Aston dealer nearby until next week.
thanks
Old May 2, 2018 | 07:13 AM
Batman-76's Avatar
Batman-76 has a spectacular aura aboutBatman-76 has a spectacular aura aboutBatman-76 has a spectacular aura about
If there is an AutoZone or some other major auto parts store in your area they can pull the code for you, free of charge.
The staff are usually knowledgable enough to provide some insight to the code as well.
Once you have the code(s) an easy google search will fill in the details
Good luck
Oh, and the port is right by your right knee, under the dash when you're sitting in the drivers seat.
Old May 2, 2018 | 09:31 AM
Z71TahoeEX's Avatar
P0130 Oxygen Sensor Circuit Bank 1 Sensor 1
P0150 Oxygen Sensor Cb2 sensor 1
Old May 2, 2018 | 11:26 AM
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
What year is your car? O2 sensors seem fairly common to need replacing on earlier cars. Low battery can also cause odd readings. If the car is running ok I wouldn't worry about it too much and you could get it looked at when you get back home. You'll fail emisssions, but that's about it at this point.
Old May 2, 2018 | 11:53 AM
Z71TahoeEX's Avatar
It’s a 12 Vantage S, 10,900 miles on it
Old May 2, 2018 | 01:09 PM
handyman2009's Avatar
Veteran: Canadian Forces
I had to replace mine at 30,000km or 18,000 miles on a 2009 V8 Vantage, in my case I replaced both side at the same time and the error didn't come back in the last 20,000kms so far
Old May 3, 2018 | 10:45 AM
howzz1854's Avatar
howzz1854 is infamous around these parts
is it hard to replace the OS sensor yourself? i wonder if it's something i can do on my own if it's easily reachable in the engine bay.
Old May 3, 2018 | 10:54 AM
Z71TahoeEX's Avatar
the lights have all mysteriously gone out
Old May 5, 2018 | 02:56 AM
cadman's Avatar
5 Year Member
cadman is a jewel in the roughcadman is a jewel in the roughcadman is a jewel in the rough
check out the marketplace forum,theres o2 sensors for sale on there..
https://www.6speedonline.com/forums/...ensor-set.html
Jeff Young
Aug 23, 2015 09:03 PM
ccrispy
Apr 23, 2014 05:20 PM
drcollie
Mar 4, 2013 07:52 AM
rye595
Jun 29, 2012 11:19 AM
