V8V won't move, possible clutch issue?
Old May 23, 2018 | 01:24 PM
J doubleU's Avatar
That's general range 13-18. When you see some above 1800 and driving, it kinda changes things. So if you were told "hey you clutch is worn out and reading 1788" would you buy a new one.....I'd roll the dice.
Old May 23, 2018 | 01:27 PM
howzz1854's Avatar
howzz1854 is infamous around these parts
interesting. i guess i should find out. will sure sure to report back as i drive it. thanks
Old May 24, 2018 | 08:04 AM
lilseevs's Avatar
lilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud of
So we had the car taken to the AM dealer, tech states that he is unable to register any sort of clutch reading
Left the car unhooked from the battery overnight, hooked it back up this morning and the car drives fine
However, reverse gear is a little jittery, it definitely seems like the clutch has shifted a bit or not kissing right. Once the car gets moving it drives completely fine like nothing is wrong at all
I am still leaning towards a bad clutch - I got in contact witht he previous dealers that serviced this car with the previous owner - they all noted the clutch has not been a maintenance item that was replaced in the past 5 years, I think it's safe to say the oem clutch has finally worn down at 32k miles
We checked all of the grounds (was thinking that potentially a ground might've come loose and is causing some sort of wonky issue), those were all fine. Literally no lights or warnings are popping up to indicate anything is wrong, which is leading me to believe it is purely a mechanical issue
Old May 24, 2018 | 08:24 AM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
Reverse is always crazy...the clutch is always grabbing and releasing on ASM ...I try to never keep in reverse more then needed.
Did the dealer finally read your clutch life?
If not take the darn car out get it in the 7000 rpm range you will know if problems...
I still believe your indie did something and not telling you.
I am glad working...keep it out of dealers etc...and drive it. I have over 36000 on original clutch...no slipping. If you do alot of highway driving remember once in gear...no wearing of the clutch on stick or ASM.
Good luck...
Old May 24, 2018 | 08:28 AM
lilseevs's Avatar
Good luck...
This is not the normal roughness of the reverse gear, it definitely seems rougher
Yes, last night the car was dropped off but AM was not able to register a reading - this is leading me to believe the clutch is too far gone to even be read?
However, does not explain how the car seems to be driving just fine in normal gears. No loss of power, no shift slippage, you'd never tell there was an issue unless you put it in reverse
It's ironic though, I do all of the work on the car myself - dropped it off for an alignment with 0 issues, next day get the call the car wont move
Old May 24, 2018 | 04:13 PM
lilseevs's Avatar
Originally Posted by hsm precision
Could the battery have gone flat? I let mine die, and all kinds of strange things happened.
Matt
What do you mean by the battery going flat? The car was able to start and run just normally, just not move. Could you explain this a bit more?
Old May 24, 2018 | 05:28 PM
lilseevs's Avatar
Well I am seriously confused
i just drove the car back home from the indy with 0 issues, I didn’t really open her up on the freeway as I was paranoid as **** - but it legit seems like there is nothing wrong with the car
Reverse feels like normal reverse, driving is normal, no weird noises or jitters
I am probably going to go ahead with the clutch replace anyways as its probably time, but am just scratching my head here. It looks like all that was needed was for the battery to be disconnected overnight then restarted
Old May 25, 2018 | 08:15 AM
Aldv's Avatar
+ 1...I agree
Old May 25, 2018 | 08:29 AM
lilseevs's Avatar
That could very well be a plausible explanation and I doubt a shop would ever come clean about that as it seems sort of embarrassing
I will drive the car around a bit and see how it performs over the next couple of days
Old May 25, 2018 | 12:52 PM
howzz1854's Avatar
i think you should just drive around see how it goes. it's very possible that it was an electronic glitch that took a reset to restart everything. you'll know if clutch is really dead within the next couple hundred miles, aka a couple gas fill-ups. i am guessing somehow the TCU had a fluke and had to be reset.
Old May 27, 2018 | 03:23 PM
lilseevs's Avatar
So i’ve driven it around the past 2 days, casually and some spirited highway pulls - the car seems completely fine
I already preemptively purchased the VelocityAP clutch last week and it looks like the car is still on it’s original clutch (from service history and prior dealership commentary of the previous owner). I may just do the upgrade anyways since the order is in and just for the peace of mind
It could very well have been just an electrical hiccup last weekend but I’d rather be safer than sorry. Hopefully this thread will help in diagnosing clutch issues for anyone in the future, as theres a wealth of knowledge in the posts made by y’all!
Old May 27, 2018 | 04:27 PM
howzz1854's Avatar
I don't know about everyone else. But I think it'll be better to wait until the clutch actually run out to replace with VAP. It's good to have the VAP in hand. But you would be throwing away unused mileage ($$) by changing it out now. Sounds like the car is running fine now. I also plan on purchasing a twin plate backup but plan on using up the original one .
Old May 27, 2018 | 04:36 PM
Aldv's Avatar
+1...also the more you have people touch your car the more sorry you will become...front end alignment ....simple job...turned into Aston Martin tow...
Chose carefully who installs this clutch...
Good luck...
Old Jun 29, 2020 | 07:48 AM
Flatty's Avatar
Flatty is infamous around these parts
Hello folks, new Vantage owner here. Experiencing the same issue today, car “let’s” me select reverse, but the “R” (reverse) red light in the dash blinks and car doesn’t move. First gear doesn’t blink but car won’t move either. Tried to disconnect the battery today in the morning, but didn’t wait for too long (maybe 1 minute?). I guess I will disconnect the battery again and let it there for several hours...
Old Jun 29, 2020 | 07:57 AM
J doubleU's Avatar
Blinking = Broken, year and miles? Have you ever had the clutch value read? If it shifts then your ASM pump is coming on. Pretty much points to a clutch, have it towed to someone who can do a proper diagnostic.
