V8V won't move, possible clutch issue?
Old Jun 29, 2020 | 10:25 AM
  #31
Flatty's Avatar
Flatty is infamous around these parts
Originally Posted by J doubleU
Blinking = Broken, year and miles? Have you ever had the clutch value read? If it shifts then your ASM pump is coming on. Pretty much points to a clutch, have it towed to someone who can do a proper diagnostic.
hello, it’s a 2008 N400. About 49.000 miles, but don’t know if clutch was already replaced and/or when. Thing is clutch used to work perfectly until the day before when I parked the car. I own the car only for two weeks now, but during this two weeks I’ve been doing clucht learns everyday, and car ride was smooth as hell. Note that only reverse blinks, if I select first gear then it doesn’t blink!
Old Jun 29, 2020 | 10:47 AM
  #32
J doubleU's Avatar
Its supposed to blink in reverse, that is normal. My fault I thought I had read blinking in 1st. Sorry. 48k miles I guarantee its had 1 clutch. Only way to figure it out is checking for codes and clutch bit counts. If it needs a clutch not much you can do but have it replaced.
Old Jun 29, 2020 | 10:56 AM
  #33
Flatty's Avatar
oh I see, since I had the car for only a couple of weeks I wasn’t sure Reverse should blink or not. Problem is I’m on a trip far from home with the car, I would love to make it ride a few hundreds miles to have it fixed on my city!
Old Jun 29, 2020 | 01:12 PM
  #34
J doubleU's Avatar
I see your in Brea, where are you stuck at? Maybe another member may be of help. With a shop or something.
Old Jun 29, 2020 | 05:00 PM
  #35
Flatty's Avatar
New info!
so I disconnected the battery for several hours, then plug it back, started the engine and did a few clutch re learns. Car did not move after choosing Drive, First or reverse. Then I tried again but reving the car up to 6.000 rpm and It suddenly kicked in and pushed the car forward. It was literally like a “violent initial kick”, I could keep moving forward after that. Then I did the same In reverse gear in order to leave the car parked where it was originally.
feels like a worn clutch to me, with a very weird behavior.
JB7
Nov 4, 2014 01:51 PM
pat
Mar 29, 2012 12:08 PM
Dr_jitsu
May 11, 2009 10:35 AM
