I need a picture
Old May 22, 2018 | 10:27 AM
embdenb's Avatar
I need a picture
I hate the roof antenna on my 2007 Vantage. OK hate might be a strong word, I believe a small shark fin would look better. Does anyone have a picture of the antenna base from inside the car with the headliner removed?
Specifically how is the coaxial cable attached etc.
Would like to know what I need, of if the project is possible before I remove the headliner.
Thanks.
Old May 22, 2018 | 11:10 AM
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
I replaced the gigantic original antenna on my 2007 with the short stubby antenna from a MINI and it looks much better. The original antenna whip just unscrews from the outside and the new antenna just screws back on.
Old May 22, 2018 | 11:11 AM
J doubleU's Avatar
It's not a coax connection 2-wire connector so you could adapt anything to it easily. You could always get a universal fin cover for $10 on Ebay and paint to match. Unscrew the post and fit the cover. Reception is almost identical with the mast removed.
Old May 22, 2018 | 02:33 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Took longer to do this post than the actual mod and looks way better than original
Old May 23, 2018 | 12:11 PM
embdenb's Avatar
Been there Done that.
I have replaced the antenna with the Mini unit, then determined that was too long. Went to a shorter "Craven" unit I believe. Finally fabricated by own 1/2 inch long unit. (See red arrow picture below) At this point the length of the antenna is not the problem, its how the antenna looks.
Not a big deal, but a picture of the underside would help be decide to do nothing or forge ahead.
Old May 23, 2018 | 12:18 PM
J doubleU's Avatar
There is just the base with threads for the mounting nut. Like most universal antennas.
Old May 23, 2018 | 12:33 PM
era2076's Avatar
era2076 is infamous around these parts
Do you have pictures of the car with the Craven and your fabricated piece?
x=chr
Old May 23, 2018 | 02:58 PM
embdenb's Avatar
See pictures below with the fabricated 1/2 inch cap and with the Craven.
(Apologize for the lack of detail)
Old May 23, 2018 | 03:08 PM
MRCW's Avatar
looks like your Aston is a bit chilly😉
Old May 23, 2018 | 05:34 PM
era2076's Avatar
I like your home made. PM if you want me to take it.
x-chr
PorschePhd
Aug 8, 2003 12:14 AM
