'09 V8VR - A few 10yo clean ups
Old Aug 16, 2018 | 11:13 AM
patrija's Avatar
patrija is infamous around these parts
As my '09 V8VR hits 10yo, there are a few cosmetic items I'd like to address
First is chrome door window trim that has started to loosen. I can push it down but it eventually loosens up again. Suggestions on what to use to adhere it?
Second is a white line that has appeared on the clear protector tape for the convertible top. The car has been cleaned and detailed ... and it will not go away. Has anyone figured out a way to remove the white line ... or remove and replace that tape?
Old Aug 16, 2018 | 02:25 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Have you tried WD 40 on a clean cloth to remove that line?
Old Aug 16, 2018 | 10:16 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
LIke CPT said, let us know what has been tried on the film. I used a compound and edge of a buffer pad lightly on a brand new V12S to remove a line. But let us know, then we can advise. Its most likely going to come back,
Old Aug 17, 2018 | 10:07 AM
patrija's Avatar
Have not, but that's a good idea. The car was just in for a clean, detail and full ceramic coat so I'm not exactly sure what they tried on it.
Old Aug 24, 2018 | 03:49 PM
karmafan84's Avatar
karmafan84 is infamous around these parts
that same thing would show up on mine every couple months. i would use a terry cloth and just a small amount of goo gone and it would look right as rain
the trim pieces I went cheap and used gorilla glue and as the chrome was losing its plastic chrome i had all the trim removed and painted to match the exterior before placing back on
when you take it off its kind of sad how flimsy and you couldnt tell it from something off a 10 year old mustang
Old Aug 26, 2018 | 02:54 PM
patrija's Avatar
ive been work traveling the last few weeks, but hope to tackle these this week
Old Aug 28, 2018 | 08:22 AM
Denver V8V's Avatar
Denver V8V is infamous around these parts
Most materials used to protect auto paint such as vinyl bras are made of UV resistant polyurethanes which are also abrasion resistant. Keep in mind the word resistance, it's UV or abrasion proof. I too have an '09 V8VR and have noticed the original bra has yellowed (amber is the technical term) and I can see the dirt lines on the edges and requires careful cleaning. So I assume your issue is a combination of both.
After you let us know what you've tried I may have a suggestion and it will be way out of the box. The worst case is you replace the vinyl strip
patrija
Jun 14, 2018 12:48 PM
kensilver
Nov 23, 2014 10:59 PM
996turbo
Apr 21, 2005 06:31 PM
