Odd smell in reverse
Old Aug 17, 2018 | 10:22 AM
DonRW2007's Avatar
DonRW2007 is infamous around these parts
A few days ago, I was reversing up an inclined driveway (~25% slope) and I thought I caught a slight burning smell, though it rapidly dissipated. Yesterday, I did the same, and not only smelled something similar to burning insulation, but saw a small puff of smoke from the passenger side hood vent. I looked under the hood but didn't see anything that looked burnt or amiss. This driveway does have some weeds and things sprouting in it, so I suppose it's remotely possible that some of this vegetation got scorched due to proximity to the exhaust (though this wouldn't explain smoke from the hood). Car acts normal in every other respect... Kind of a crazy issue - has anyone had a similar occurrence or have any ideas?
Thanks, DRW
Old Aug 17, 2018 | 12:25 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
That would be your clutch ;-)
Old Aug 17, 2018 | 12:40 PM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Clutch! You might wanna refrain from reversing up inclines.
Old Aug 17, 2018 | 12:45 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
It's not really burning any more in R than in 1. R is a bit taller a gear than 1, but we feather the clutch more in R because nobody is as confident backing these up as they are driving them forward. The reason you smell it is because the reverse airflow pushes the burn up into the cabin that you don't get in forward where the airflow pushes it back and away from the cabin.
Old Aug 17, 2018 | 01:41 PM
J doubleU's Avatar
Smells like dead presidents
Old Aug 17, 2018 | 02:09 PM
DonRW2007's Avatar
Thanks, all. That stands to reason... You’d think that after 44 years I’d have mastered the art of backing up!
Old Aug 17, 2018 | 04:29 PM
XJRS Owner's Avatar
Don't feel bad, this happens to everyone with an Aston. They are the worst cars for backing up, ever. And since you don't use reverse often, you never get used to how easy they are to stall (or burn up the clutch). Just get used to the 'parfum de clutch'...
Old Aug 18, 2018 | 12:54 PM
5 Year Member
You'd think after 2 years I'd know where the front, back, and corners of my car are. Nope, not a clue. I crawl and put the parking sensors on anytime I'm pulling up or backing up to anything!
DBS996
Oct 6, 2005 02:04 PM
californian
Aug 2, 2005 11:21 AM
