Keys for v8v
Old Nov 25, 2018 | 11:18 AM
lovingit's Avatar
lovingit is infamous around these parts
Keys for v8v
I got a plastic key fob and a glass key fob delivered with my v8v. Does the key fob give any indication of when battery is going to go out because I don’t know if or when the previous owners changed them. Is there also supposed to be a normal metal key that you can use to open the door?
Mine did not come with a metal key. Unless it’s like some of the BMWs were you can pull the metal key directly out of a key fob and use it to unlock your door?
Old Nov 25, 2018 | 12:26 PM
Dalecannavan's Avatar
5 Year Member
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
Not sure on the battery, but the metal key is completely independent. You should be able to order it from your dealer.
Old Nov 25, 2018 | 01:05 PM
62Jeff's Avatar
62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !62Jeff Is a GOD !
Key fob does not have an indicator (such as a flashing light) letting you know the battery is low, however the functionality becomes sporadic.
For what little it costs, just replace the batteries yourself and know what you have.
Instructions for replacing batteries
Plastic fob - https://www.6speedonline.com/forums/...placement.html
Crystal fob - https://www.6speedonline.com/forums/...ml#post3699855
porschedog
Scheduled Events
10
Nov 22, 2006 04:52 PM
RDH
Scheduled Events
19
Mar 16, 2005 12:17 PM
M3CAB
Mar 9, 2005 01:25 PM
EM 996 GTS
Nov 26, 2003 05:30 AM
