VelocityAP Airbox Delete Kit for V8 Vantage, V12 Vantage, DB9, DBS, Vanquish, Rapide
Old 12-01-2018, 11:59 AM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Hi Everyone,
We've had a V12 Vantage in the shop for an extended build (turned a little longer due to some brake-wheel clearance & fiddling.) Our resident Guru Chris (aka. Irish007 aka Tuning@VelocityAP) worked with the guys in our fab shop to design an airbox delete system for this car which allows a cone filter to be fitted. It worked out so nicely we've had it patterned and will be producing it for resale.
It consists of two CNC Lasered & bent 11G stainless brackets. These bolt directly to the factory mounting points on the chassis. Two small holes and some stout cable ties hold the MAF tube in place.
The filters we used for the prototype are designed for a 3" inlet tube, whereas the MAF tubes are 3.25" so we're having the filters specially made for ease of fitment. They contain an integrated silicone neck and clamp so they affix firmly to the end of the MAF tube, with no risk of falling off or coming loose. The filters are also an open funnel style so have substantially more surface area than a normal cone or cylinder filter.
Kits will include:
- LHS Bracket
- RHS Bracket
- Cable Ties
- 2 x 3.25" Inlet Open Funnel Cone Filters
We have a fair bit of lead time on the filter manufacturing, probably about 6 or 8 weeks. If people are interested, we can probably set up a group buy/pre-release special offer with a discount.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old 12-03-2018, 05:15 PM
Originally Posted by RejeX
I would be interested in a group buy.
Okay I'll continue to canvas and then maybe we can set something up.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old 12-04-2018, 03:43 PM
007JB's Avatar
007JB has a spectacular aura about007JB has a spectacular aura about007JB has a spectacular aura about
Stuart
I'll be interested too. Can we use filter that we bought from you? is it same size ?
Old 12-04-2018, 05:25 PM
Originally Posted by 007JB
Stuart
No. These are not stock fitment filters. The OEM filter is held in place by the airbox itself, basically it just slides onto the inlet neck, but when you put the two halves of the airbox together it pushes up on the base of the filter and holds it in place. Without that airbox the only thing holding the filter on is some elasticity of the filter body on the inlet tube.
These filters have a tapered silicone 'exit' side, with a cylindrical exit so you can use a screw clamp to hold them firmly in place, and not worry about them wiggling their way loose over time or hard driving conditions.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old 12-05-2018, 05:53 AM
brightoncorgi's Avatar
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
What are the advantages of going to this vs. the OEM application?
Old 12-05-2018, 07:06 AM
MRCW's Avatar
My same question! Any risk of water intrusion?
Old 12-05-2018, 09:27 AM
More Power, More induction noise!
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old 12-05-2018, 09:30 AM
Always some risk when removing the airboxes. That said, the race cars use a similar setup, have run in the wet without issue. From what we've seen you'd pretty much have to drive into a puddle at speed to hydrolock the engine.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old 12-05-2018, 09:52 AM
If I already have a VelocityAP tune, will adding more air require a file update? No big deal either way, as you guys have made this process very easy. Just curious.
No, changing up for this setup won't require a new calibration.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old 12-05-2018, 10:29 AM
Mathman85's Avatar
Mathman85 is a glorious beacon of lightMathman85 is a glorious beacon of lightMathman85 is a glorious beacon of lightMathman85 is a glorious beacon of lightMathman85 is a glorious beacon of light
This.
You'd have to be seriously reckless about driving through standing water, submerging most of the filter in the process, for the intake to actually draw in water. I'd hope nobody is practically fording rivers in their Aston... lol
Old 12-05-2018, 11:17 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Originally Posted by Mathman85
This.
The entire filter would need to be submerged. Try sucking water through a straw with a hole in it, doesn't work.
Old 12-05-2018, 12:17 PM
Liilpa09's Avatar
Liilpa09 is on a distinguished road
I’d be willing to give this a shot as well.
Old 12-05-2018, 12:25 PM
cadman's Avatar
cadman is a jewel in the roughcadman is a jewel in the roughcadman is a jewel in the rough
rich at redpants has already developed this ?whats is the the difference with the VAP one ??
Old 12-05-2018, 12:51 PM
Liilpa09's Avatar
don’t think he has a V12 option...
Old 12-05-2018, 02:23 PM
J doubleU's Avatar
V8 or V12 it's the same setup......
Quick Reply: VelocityAP Airbox Delete Kit for V8 Vantage, V12 Vantage, DB9, DBS, Vanquish, Rapide
