Annoying squeal from rear wheel?
One of my rear wheels (I assume it's the brake) is squealing almost constantly. For some reason the squeal quiets down after making left turns, but increases substantially after making right hand turns. The squeal will continue until I make a left turn.. I assume this is just causing a rear brake pad to shift a bit, but concerned there may be a more serous issue.
It sounds like brake squeals are a very common thing on the Vantage, but I'm curious if this is common while driving normally and not while braking. Anyone have thoughts on this?
Thanks in advance.
Thanks in advance.
Schreech...what the hell was that?
Happened to me twice. Horrible, slow speed noise. Pulled into a convenient church parking lot. Backed a couple feet, noise was gone. Same , "dodged a bullet" feeling you had.
Second time, years later, as I entered my favorite gas station (over priced but easy approaches and never crowded). Same noise, it turned out to be a small acorn. Now I was an expert. Backed up a foot or two and I heard it hit the ground right behind my ear.
Both occurrences, I believe, were to rear wheels. Seems the design of the aluminum brake stone shields, incomplete light weight stamped circles, inboard of the rotors, can trap small, just the right size, not too big, not too small, stuff.
007 Vantage
Sep 6, 2023 03:50 PM
DNugget991GT3
Jun 13, 2008 09:47 AM
