Trunk not opening 2014 Vanquish
Old Mar 17, 2019 | 06:44 AM
mendolia's Avatar
mendolia is infamous around these parts
Despite pressing nipple on trunk, using glass key and trunk release button on inside driver door panel the trunk will not open...with each maneuver a clicking sound can be heard which to me implies the actuator is functioning....door locks and glove release box work fine...dash indicator shows 'trunk lid open'...spoke to service managers at 2 locations, both unable to add any additional suggestions...no access to trunk from interior...any suggestions????
Old Mar 17, 2019 | 09:32 PM
XJRS Owner's Avatar
Push it down firmly, by hand, then try again.
Old Mar 18, 2019 | 05:05 AM
mendolia's Avatar
Unfortunately the same result after numerous attempts
Old Mar 18, 2019 | 10:47 AM
embdenb's Avatar
Not familiar with the Vanquish, is the trunk completely closed off from the cabin? If you can get to the trunk via the rear cabin by removing the rear seats, then
you should have an emergency manual release method accessible within the trunk.
Old Mar 18, 2019 | 01:28 PM
mendolia's Avatar
no access from cabin
Old Mar 18, 2019 | 04:49 PM
Viper98912's Avatar
5 Year Member
Viper98912 is a jewel in the roughViper98912 is a jewel in the roughViper98912 is a jewel in the rough
Jeez, there's no key hole or anything? There's gotta be something...
Old Mar 18, 2019 | 08:26 PM
docroc's Avatar
docroc is infamous around these parts
I bet something is stuck in the door jam since the actuator is apparently working. I had that transiently happen on mine and there was something stuck in it. As someone else mentioned, I just pushed on the trunk of my Vanquish and it worked the next time with the driver’s side window trunk release though. Your local dealer really said they couldn’t help??
Old Mar 19, 2019 | 04:17 AM
mendolia's Avatar
thats my thinking as well...dealer said they may have to access the manual release by removing one of the rear lights...trying to avoid this option
Old Feb 11, 2024 | 08:37 AM
Geflackt's Avatar
Geflackt is infamous around these parts
Did anyone come up with a solution for this trunk issue?
My trunk lid is stuck closed now and showing a "Trunk Open" message. Pressing the door or exterior button results in a faint click at the latch, but that's it. It's done this to me before and usually fixes itself after everything goes to sleep. However, I had it shut down overnight, plus disconnected the battery this morning and no change. I've also tried pushing down and pulling up on the trunk lid, but there's no change.
Strange because when it closed yesterday, the soft close mechanism pulled it closed as I was trying to get the lid up.
Update: Found the wire that tells the car the boot is open. Grounded it - message went away. No change in opening. Just a click when hitting the exterior button, door button, or key fob. Did the battery reset procedure again(with window and seat cal). No change. Locked car for a while thinking it's lock/alarm related. No change.
Removed the rear seats and panels. Got access to the trunk. Managed to get a hook on the trunk release. Will not budge. I was able to get quite a bit of force on the release, although it's pulling it straight to the front and not to the side. Still stuck.
Old Feb 12, 2024 | 05:52 PM
Geflackt's Avatar
OPEN!
That was an adventure. Managed by going in through the interior and the hole in the parcel shelf to unscrew the striker on the trunk lid. Great! But no, the striker is bolted to the pushbutton switch and the angle of the trunk kept it from opening more than about an inch. Worked on it a while and finally decided to get a hacksaw blade in and cut part of the striker. Trunk opened!
With the striker still in the latch, the latch would still not open. That striker is also in the way of a screw for the entire panel. I played with jamming things into the latch, but no real difference. Finally decided to turn the convenient green "gear" on the auto close mechanism which loosened a cable to the latch. BINGO! The latch clicked open!
What I found is that a position switch on the auto close mechanism was out of alignment. The auto close mech would stop part way through pulling the trunk closed, which would not allow the trunk latch to spring free. However, I don't think this is the only issue because the mechanism has gotten confused before but not like this.
So the solution: If you have a stuck trunk but still hear the "click" to release, the auto close may be out of sync. Go in through the interior, somehow pull the carpet away from the rear floor, and use a large torx bit to turn the rear gear until it stops(may have to try both directions).
Old Feb 19, 2024 | 06:45 AM
bjmsnlaw's Avatar
bjmsnlaw is infamous around these parts
Thanks for sharing guys. Mine worked after many attempts, finally! Very helpful insights and what a good problem.
Old Jun 3, 2024 | 06:04 AM
J9SHT's Avatar
J9SHT is infamous around these parts
Hi, Thanks for posting your update. Unfortunately I have exactly the same problem with my 2014 vanquish boot not opening.
The challenge I have is that I stupidly may have overfilled the boot and now it wont open, my worry is even if I remove the rear seats, etc the boots full of my stuff and will I be able to get past of the of this stuff in the boot to get to the manual boot release/latch?
How big is the hatch to the boot when you remove the seats? do you have any pictures by any chance?
I have found a YouTube clip for the DB9 but unsure if this is the same as the vanquish? it talks about a pre drilled hole in the boot floor next to the manual release this is accessed by removing the rear right wheel and wheel arch lining and then put something through to pull on the release?
DesotoJohn
Bentley
14
Oct 25, 2024 04:02 AM
tarnow1942
Bentley
10
Oct 30, 2020 01:02 PM
JohnnyRocker
Aug 22, 2018 02:49 AM
Zaos
Bentley
Jan 25, 2017 01:13 PM
Red Devil
Dec 30, 2003 08:16 AM
