When I charged the battery it tripped the cutoff
Old Jun 26, 2019 | 04:02 PM
geodavky's Avatar
geodavky is infamous around these parts
Car stopped dead
Backing my V8V out if the garage it stopped dead. The battery cutoff switch had not been touched, but all systoms were down just as if the switch had been set. I used the reset button behind the seat, but nothing happened and everything was still dead. About 45 minutes later the car started fine. What would make the car stop dead like this?
Old Jun 27, 2019 | 08:20 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Doesn't sound like the battery switch but it does sound like the battery. Are the battery leads tightly secured?
Old Jun 27, 2019 | 09:19 AM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
I'd check you battery for sure. There a lot of places will test them for free. But the downside is they aren't the easiest batteries to take out. Summer driving /heat and A/C use can put a strain on a older or weak battery? You said you charged your battery.... do you used a battery tender? If not, I would suggest one unless you're Aston is a daily driver.
Old Jun 27, 2019 | 09:35 AM
geodavky's Avatar
Does the test hav to be done directly on the battery or can it be done from the outlet in the engine compartment?
Old Jun 27, 2019 | 09:41 AM
Ozzir's Avatar
Ozzir is infamous around these parts
The first thing you need to do is make sure the positive and negative cable are really tight on the battery. Get access to the battery and tighten the cable clamps. If there is any corrosion at all on the posts then you need to take the cables off and clean them. You can test the battery's voltage from the positive post under the hood but you cant do a load test on the battery from there. The battery will have to come out to do that or you will have to take it to a shop that has a portable load tester. It sounds more like a cable problem or possibly a bad ground cable under the car somewhere.
PKAutoParts
Aug 26, 2016 08:23 AM
wanderfalke
May 12, 2014 11:05 PM
PeterC4C
Oct 30, 2004 10:34 PM
