OBD-II scanners for 2007 DB9
Old Aug 23, 2019 | 09:14 PM
sliderule01's Avatar
sliderule01 is infamous around these parts
Hi all - I just realized (I am a bit slow) that a lot of effort could be solved with me having my own OBD-II scanner. I have done the 'net search, and found the Foxworth NT520 to be appropriate for my DB9. Are there any others that would be good? What is the collective wisdom regarding scanners? With the recent issue with my airbag warnings, I want to be fully armed whenever I go to dealer or indy mechanic. I also found an indy mechanic in the Philly area that specializes in AM. I appreciate your help.
Scott
Old Aug 28, 2019 | 04:10 AM
thanuja's Avatar
thanuja is infamous around these parts
Congrats on the new car Scott, I have a DB9 and live in Hockessin, DE so interested in the mechanic info . Based on the FB AM groups, most use the simple amazon bluetooth scanner with an android device. A friend of mine uses the bluedriver on his vantage. Hope this helps.
Old Aug 28, 2019 | 03:39 PM
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
Steel Wings in Warminster Pa outside Philadelphia are the best independent I have found.
Good Luck...
Old Aug 28, 2019 | 08:37 PM
Good Luck...
That is who I was planning to use, although heard good things about Red line Motors in Pottstown. 60 minutes one way and 40 the other.
Old Aug 28, 2019 | 08:55 PM
Aldv's Avatar
Hi Scott... I do not know the other company. Jon at Steel Wings...rebuilds old Aston Martins but is able to stay current with the modern Astons...
Very honest company that cares about your car...I had them install rear tires and other stuff done on my car two months ago.
Prior work was changing all the fluids and filters when I first got my car.
If you are a dealer type guy...I found Summit in North Jersey better then local AM dealer.
I would suggest if any doubts visit Steel Wings and the other company...then decide for yourself...
Good luck
Duke
Old Aug 28, 2019 | 09:06 PM
I have heard excellent things about steel wings - they are first choice. If I can't get se.at calibrated...I will go to them.
Old Aug 29, 2019 | 04:15 PM
DetomasoGTS74's Avatar
Scott
I believe you mean Foxwell NT520. That is the one you want to buy, do not buy one of the Bluetooth ones as advised above. The foxwell will enable you to access all Aston specific vehicles, systems modules and control units. The link below will help guide you through everything you need to know.
https://aston1936.com/2017/12/17/aff...-obdii-reader/
Old Sep 1, 2019 | 12:47 AM
V12Stealth's Avatar
5 Year Member
V12Stealth
How is the Foxwell 6xx devices different from the 5xx? The 6 series seems to have all cars out of the box.
Old Sep 1, 2019 | 04:56 PM
zzzamdb9's Avatar
5 Year Member
zzzamdb9 is infamous around these parts
I think the 5xx series have more features than the 6xx but you only get 1 free marque on the 5xx.
FYI there is currently a flash sale including the NT530.
https://www.foxwelltool.com/wholesale/latest-nt530-multi-system-scanner-one-free-software-nt520-updated.html
Old Sep 2, 2019 | 06:43 PM
I just purchased the Foxwell NT520Pro (Aston Martin version) moments ago. Should arrive in the next few days. That is a good thing, as I got a CEL and warning "Emissions Systems Diagnostic" message as I was driving home. I think that the bad & rough roads on the way home, along with lots of rain probably got the sensor wet or shook the connection loose - speculation on my part. Car ran great, and I got excellent gas mileage - 22 mpg on the highway (I wasn't driving very fast).
Old Oct 30, 2019 | 03:58 PM
Dinomd's Avatar
Dinomd is infamous around these parts
Sliderule01,
I'm in Reading PA and just had the same Emmissions warning. I ordered the Foxwell NT520 and they sent me the newer NT530. It seems to work fine for me and I just replaced the MAFs and solved my issues. How did yours work out?
Old Oct 30, 2019 | 04:21 PM
It worked out well - cleared the codes and it hasn't returned yet. I still need to clear the airbag warning for passenger side but I need to calibrate the seat first. If the weather is nice this weekend, I will attempt it. BTW, I am just down 422 from you at Collegeville. Nice have someone close for questions.
gtmule
May 6, 2021 07:42 PM
André CHARLES
May 5, 2019 12:59 AM
riverflyer
Oct 4, 2017 05:39 PM
All Mack
Apr 24, 2017 01:50 PM
LIDB9
Oct 5, 2016 07:34 AM
