brake fluid change... anything special or needs resetting?
Old Sep 18, 2019 | 09:20 AM
MRCW's Avatar
changing brake fluid sometime next few weeks... anything special needs to be reset? Modules, ABS , etc or a simple flush fill and bleed?
Old Sep 18, 2019 | 02:16 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
I use a Motive pressure bleeder. No special process. But it doesn't flush the ABS pump, which is typically a very small amount of fluid. I suppose if I thought about it, I'd stab the brakes to cycle that fluid, but I've not bothered.
Old Sep 23, 2019 | 07:42 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
To flush the pump, start car and pump brake once or twice while pressure bleeding. Do this for each caliper.
Old Sep 23, 2019 | 08:09 PM
blue2000s's Avatar
To my understanding, that won't flush the fluid in the ABS pump. Only cycling the ABS pump, either through the AMDS (as Aston instructs) or through activation on the road can do that.
Old Sep 23, 2019 | 08:30 PM
randyb's Avatar
This has worked on other cars, but thanks for clarifying.
Old Sep 23, 2019 | 08:54 PM
blue2000s's Avatar
I'm genuinely curious on which cars that works. I've never heard of this before.
Old Sep 23, 2019 | 09:07 PM
kdm's Avatar
kdm
5 Year Member
kdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of light
When I flushed the brake fluid on my 2007 V8V, I took it out on the road when it was raining and did a few hard stops which activated the ABS. Came back and did another regular brake line flush at all 4 wheels. Probably over kill but it was just 1 more bottle of fluid
Old Sep 24, 2019 | 05:19 AM
MRCW's Avatar
thanks for the clarifications.
Old Sep 24, 2019 | 11:04 PM
randyb's Avatar
It worked on my Jag and if I remember right also my vette.
Old Sep 25, 2019 | 04:32 AM
handyman2009's Avatar
Veteran: Canadian Forces
Don't forget to also flush the clutch at the same time as it is often forgotten... I don't think mine was ever done seeing how black the fluid came out... You will have to go under the car for that one, right by the clutch.
Old Oct 8, 2019 | 04:11 PM
MRCW's Avatar
well after talking to my dealer, I think for $250, I'm going to have them do the brake and clutch fluid change... with the hassle of purging ABS and the AMDS for the ASM clutch, seems reasonable...
besides, they always do courtesy alignment check and system check for the car.
Sobrut911
Feb 17, 2013 07:58 PM
NineElevenLover
Jan 8, 2012 05:52 AM
Dally
Jul 21, 2010 02:46 PM
ryem3
Jul 6, 2009 09:53 AM
r34dy2walk
Feb 28, 2008 05:40 PM
