Brake fluid leak
Old Oct 30, 2019 | 08:42 AM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
Brake fluid leak
I've got my 09 V8V in for an alignment today (for some reason it's missing a lug nut on the right front wheel, wtf?). While it was up in the air the techs noticed a brake fluid leak around the bellhousing area, and the fluid is getting on the cats and smoking.
Is this common? What should I check?
Old Oct 30, 2019 | 11:30 AM
deckman's Avatar
Brake fluid is corrosive to soft things on our cars. Are they inspecting any rubber or plastic the fluid may have in contact with?
Old Oct 30, 2019 | 11:35 AM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Sadly this is a leaking slave cylinder. Can be caused by not bleeding old brake fluid from the clutch system every couple of years. Need to pull the torque tube and inspect/repair/replace. Given the cost to get in there, a close look at the clutch pack is probably warranted as well.
Good luck with the repair!
Old Oct 30, 2019 | 11:39 AM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
How does the technician know it's brake fluid? The bleed nipple for the clutch fluid protrudes from the bellhousing. Perhaps that is the source of the leak? Clutch and brake fluid leaking is absolutely not normal and I'd work to fix that right away.
Old Oct 30, 2019 | 12:05 PM
Kalepsis's Avatar
5 Year Member
Damnit. I just bought the car and now I have to do a multi-thousand-dollar repair to replace the slave cylinder/throw-out bearing. I didn't expect this right away.
Looks like I'll be parking it for a while. Ugh.
Old Oct 30, 2019 | 02:14 PM
AM4884's Avatar
5 Year Member
Hope springs eternal. Too be fair, I was thinking leaking from inside the bell housing and out the weep hole. It could be coming from the nipple and down the outside. If so, go buy a lottery ticket or two with the savings.
Old Oct 30, 2019 | 02:18 PM
Kalepsis's Avatar
5 Year Member
I'll look at that. But, with my luck it'll be the worst, most expensive thing to fix.
got one
Dec 22, 2016 05:50 AM
BradB
Jun 21, 2015 09:08 PM
007 Vantage
Feb 19, 2014 08:53 AM
bonehead
Jun 6, 2012 01:18 PM
