Fluid Level Check?
Old Jul 28, 2016 | 07:22 PM
got one's Avatar
got one is infamous around these parts
Fluid Level Check?
Just curious, how do you check the clutch/trans fluid on 07 vantage sport shift?
Also, how do you check the diff fluid level?
Coolant, brake fluid and engine oil fluid checks I am good with.
Thanks!
R
Old Jul 29, 2016 | 01:04 PM
got one's Avatar
bump for a good cause
Old Jul 29, 2016 | 01:13 PM
telum01's Avatar
Clutch fluid is same as brake, transmission fluid doesn't really get checked, just changed based on time/miles.
Old Jul 29, 2016 | 02:11 PM
got one's Avatar
so checking the level of the brake fluid reservoir is the same as the clutch fluid?
Old Jul 29, 2016 | 02:44 PM
J doubleU's Avatar
Not on a Sport Shift, there is a reservoir mounted on the left side of the transmission in front of the axle shaft. Special fluid required. Pentosin CHF 11s.
Old Jul 29, 2016 | 02:45 PM
got one's Avatar
So, is there a way to check fluid level?
Also, any idea on the diff?
Old Jul 29, 2016 | 02:58 PM
J doubleU's Avatar
The clutch fluid reservoir should be around 3/4 mark. No leaks should be fine. Transmission check/fill plug on RH side. Same as most vehicles to check.
Old Jul 29, 2016 | 03:17 PM
got one's Avatar
Diff fluid check?
Old Jul 29, 2016 | 03:50 PM
J doubleU's Avatar
Old Jul 29, 2016 | 03:59 PM
got one's Avatar
I see final drive...what is that?
Old Jul 29, 2016 | 04:36 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Aston Martin V8Vs do t have separate gearboxes and differential units . Its all combined into one unit .... The transaxle ...hence the name .
Old Aug 1, 2016 | 02:45 PM
got one's Avatar
Sorry guys, still not clear on how to check the fluid on the transaxle.
Also, where does the gearbox oil go vs. the final drive oil?
Just want to be crystal clear for myself and others...
Old Aug 1, 2016 | 03:15 PM
Vantagelvr's Avatar
Gearbox + Differential/final drive = Transaxle . One fluid ,one plug ,one check . Take the plug out put your finger in and you should feel it barely below the plug opening or it may actially dribble out depending how level the car is .
Old Aug 2, 2016 | 07:07 AM
got one's Avatar
So, why then are they two different fluid weights if it is one fill?
Old Dec 17, 2016 | 08:19 AM
Seostu's Avatar
Seostu is infamous around these parts
Fluids on vantage v8
Thanks!
R
hi R
i think I have just the same problem to solve - just paid £2k to a uk dealer for a service and explicitly asked them to check power steering fluid - when checking myself later (on uk model it has a black daisy like wheel lid at front right - so opp side to oil change and diametrically opposite brake fluid) discover can see the base of the reservoir (has a strange ring showing like a polo mint) and typical Aston no upper or lower clear markings on the dipstick...so have no clue if it's correct level or not!
