Sport Shift Gearbox Issue
Old Oct 30, 2019 | 01:50 PM
LotusJPS's Avatar
LotusJPS is infamous around these parts
Had something bizarre happen driving my 2010 Vantage yesterday. Was driving along in 5th gear (~40mph) and as I started going up a slight incline it suddenly jumped into neutral. I hit the up shift paddle and it went back to 5th, though when I pressed on the accelerator the revs came up like it was still in neutral (even though the dash showed "5"). I then hit the down shift paddle and it went into 4th, then drove fine again (including going back up to 5th and 6th). Any ideas what could possibly cause this? I have noticed that "occasionally" lately it's be slow shifting from 1 to 2, or 2 to 3, but it's very inconsistent when it does it.
Not sure if it could be the clutch, transmission control module, or something else.
Any thoughts would be greatly appreciated!
Old Oct 30, 2019 | 03:02 PM
sonies's Avatar
5 Year Member
sonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud ofsonies has much to be proud of
i'd change your gear oil first
Old Oct 30, 2019 | 03:10 PM
LotusJPS's Avatar
It was changed about 400 miles ago (this summer). The car currently has 15,900 miles on it.
Old Oct 30, 2019 | 03:40 PM
XJRS Owner's Avatar
Weak SSM pump? Low on hydraulic fluid?
Old Oct 30, 2019 | 04:14 PM
MRCW's Avatar
low on fluid or perhaps clutch not purged properly? Dealer has to reset the clutch after fluid change for the clutch and brakes... Did you have clutch and brake fluid changed at same time?
Old Nov 1, 2019 | 12:22 PM
NotanM's Avatar
NotanM is infamous around these parts
Changing the gear oil isnt going to help with jumping in and out of gear FYI.
Are you properly starting the car and letting the car learn clutch depth?
Perform 15 cold clutch learns, than take it out for a good drive to blow out the cats. Clutch is probably failing. Does it chatter at low speed/reverse? Based on the age & miles on your Vantage, i'd beat your ASM lines are probably dry cracked and sweating and your ASM fluid is probably low. Just an FYI an ASM car does not use the same master cylinder like the manuals do. The ASM fluid is Pentosin, where on a manual car the MC used DOT 4 brake fluid.
Keep us updated!
Old Nov 2, 2019 | 05:48 AM
J doubleU's Avatar
5th gear @ 40mph? Its probably just pissed off at your driving style. It was just preventing more damage by selecting a lower gear, computer took control.
TarHeelVantage
Jan 11, 2019 12:49 PM
rbobby
Nov 9, 2013 07:00 PM
snopdog911
Apr 25, 2011 09:33 AM
TrackAddict997
Apr 19, 2010 10:53 AM
SXN
Jun 17, 2008 11:53 AM
