Transmission filter oring.
Yup, that's the one. O-rings can be reused a few times, but if I can get the size, I can buy the rings for nearly nothing. I bought a lifetime supply of bypass filter orings for about $0.10 a pop.
The o-ring dimensions are 2.62x20.63. I've seen some green (Viton?) and some black, so I'm not sure what the best material is.
The copper crush washers for the transaxle drain/fill plugs are 22x28x1.5, in case you need them.
Great! Thanks.
