DSC Temporarily Off at Start-up - Randomly
Old Nov 4, 2019 | 07:49 AM
sliderule01's Avatar
sliderule01 is infamous around these parts
I just noticed that I am getting DSC off at random times at start up of my 2007 DB9 Volante. Car goes through system check then quickly get this warning after I start car. It goes away quickly, and shows no red or yellow alerts. I am assuming that DSC means "Directional Stability Control" - I don't drive that aggressively, and rarely activate the traction control - usually it is because the tires are cold and I accelerate too quickly. Is this just one of those quirky things that I should ignore, or pay some attention? The weather has been a bit cold lately (0C) so that might be causing issues.
Scott
Old Nov 4, 2019 | 02:04 PM
J doubleU's Avatar
Have your battery tested, on start up if it goes low and doesn't recover the car sees below 12v and will issue a fault message.
Old Nov 5, 2019 | 01:02 AM
MRCW's Avatar
I had a similar problem on my BMW and it turned out to be bad ABS sensor... maybe get that checked...
Old Nov 5, 2019 | 04:57 AM
Chris Jackson's Avatar
Chris Jackson is infamous around these parts
Scott
I had this with error stating DSC Temp Off and DSC Service required. Turned out to be a Faulty Brake Pressure Transducer Failure, £90 part from aston (only place to get it) and a 5 min job with a 24mm spanner (its on the underside of the Brake Servo unit (Looks like has a big silver nut) Undo counter clockwise (as in turn towards drivers side if a UK car) but have a little cup under to catch the little bit of brake fluid you lose), pop the new one on and voila!
Old Nov 5, 2019 | 05:56 PM
I have driven it multiple drive cycles and it has not reappeared. Perhaps the battery is getting a bit old - having purchased the car in September, and the car sat on the lot for a while, the battery may be on its last legs. I will check the date on the battery.
Old Nov 6, 2019 | 11:26 AM
MRCW's Avatar
Good idea on battery... so many cars these days experience random glitches because of weak batteries... I replace then every three years or so in all my vehicles and boats.
goldsmin
BMW //M
Oct 17, 2017 11:37 AM
jordonmusser
Jan 22, 2017 04:37 PM
Aston22
Jul 5, 2016 09:08 AM
XJRS Owner
Aug 19, 2013 07:10 PM
crosvs
BMW //M
Mar 24, 2007 10:22 AM
