DB9 3-Pin Coil Packs
Old Mar 15, 2020 | 03:31 PM
ragpicker's Avatar
ragpicker is infamous around these parts
Originally Posted by bavarianstance
nice find. I also found that OE/M suppliers SERGEY and BAIXINDE have V8 Vantage Coil Packs as well. I just copped a set for $100 off ebay for future use.
I'd hazard a guess and say these are the same units being offered by US resellers but are charging 800-1000% markup.
Very interesting. Are SERGEY and the other one actually the OEM suppliers? I like the look of the coils but they don't have the fixing hole at the front like the OEM coils.
Old Mar 15, 2020 | 04:57 PM
bavarianstance's Avatar
5 Year Member
bavarianstance is infamous around these partsbavarianstance is infamous around these parts
I doubt these Chinese made brands are OEM suppliers. But they are OE equivalent/replacements. I don't even know where to source OEM coil packs besides from the dealer. And I'm afraid I don't have OEM MFG/supplier information, but I would think it would be some German supplier like BERU or BOSCH.
All I'm saying is I've seen non-OEM coil packs being sold for $800-$1000/set and I wouldn't be surprised if these were just re-branded Chinese parts being sold at massive markup.
Old Apr 2, 2020 | 08:23 PM
sliderule01's Avatar
sliderule01 is infamous around these parts
I have continued my search for the coils. From the latest information I can determine, the 3 pin coils have a model number of XR1U-12A366-AB. There are also the Beru coils which are probably the OEM. I am having my coils done now (ouch). I wish I had the talents to do my own but my wife hides tools from me.
Old Oct 28, 2020 | 09:46 AM
call2sala's Avatar
call2sala is infamous around these parts
Originally Posted by sliderule01
Doing a lot of searching, it looks like the equivalent to the 3-pin 8G43-12A366-AA are the BERU tel:0040100388]0040100388 or a ZS388. I have not found anything so far in the US. The Beru ZS388 has 3 pins and looks like it is the best 3 pin fit. A Champion BAE A388 also appears to be a good number - see https://www.onlinecarparts.co.uk/oenumber/8g4312a366aa.html]here
I looked on this https://partinfo.org/beru-zs388/]link]https://partinfo.org/beru-zs388/]link
and https://www.sparkplugs.co.uk/beru-ignition-coil-zs388]here
I have an extra pair of 12pcs with 3 pins but part number 4G43-12A366-AA wherein I believe it should have been 8G43. Well I guess with AM it does mix part numbers probably during the transition phase.
Old Apr 21, 2021 | 01:20 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
I wonder how the offbrand coils fair. I had the upgraded Genuine 8g43-12a366-aa coils fit at 24k miles and now at 47k miles a few are already miss firing. First set from new lasted only 24k miles, second set lasted 23k miles. Gone are the days where one just replaces all coils. If you find a good coil, keep it, just replace the bad ones.
I think I'm just going to err.. "upgrade" my manifolds like they do in the UK so I never have to think about ceramic ingestion. I don't want to get stressed out every time I have a little miss.
Old Apr 21, 2021 | 03:24 PM
What is the "upgrade" to the manifold?
Old Apr 21, 2021 | 06:14 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
rumor has it some people remove the catalytic converter from the manifold to avoid having it sucked back into the engine (which will destroy it). Or so I'm told.
Old Apr 22, 2021 | 06:29 AM
Bones 53's Avatar
5 Year Member
Bones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud ofBones 53 has much to be proud of
Rumor is true that catalytic converter failure can destroy an engine. Happened to me. AM replaced engine under extended warranty.
Thanks,
JH
Old Apr 22, 2021 | 02:23 PM
8Tech's Avatar
5 Year Member
8Tech is infamous around these parts
Absolutely true, if a misfire allows unburnt fuel to enter the close coupled cats in the exhaust manifold, they overheat and break up, throwing their insides back up the xhaust port during scavanging, past the exhaust valve and destroy the motor. Hot tip is to gut, or remove those cats and move the O2 sensors to prevent emissions warning lights.Here are a set where my stock headers have had the cats cut out and replaced with tube.Installed with exhaust wrap to retain heat in exhaust, reduce underhood temperatures and protect adjacent components.
Old Apr 22, 2021 | 04:39 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
Looks very neat.
Old May 1, 2021 | 03:59 PM
Phil57DBS's Avatar
5 Year Member
Phil57DBS is infamous around these parts
for more reliability and because of the excessive heat, I definitely removed the sheet metal cover above the coils ...
Old May 2, 2021 | 12:54 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
That seems like a good idea. But doesn't that cover prevent water ingress in the rain? Can you post a photo of what it looks like now?
V12 Jags used to have heat related ignition amplifier failures and some companies would even sell a kit of bolts and spacers to just lift the amplifier an inch off the engine block and that was enough to keep it working.
Old Feb 14, 2022 | 05:23 AM
Benson9's Avatar
Benson9 is infamous around these parts
Hi, As anyone used BERU coils in the end ? How did they fit ? All good ? Any issues to report ?
I was also wondering if they where the original suppliers to AM ?
Thanxs
Old Feb 14, 2022 | 02:13 PM
kdm's Avatar
kdm
5 Year Member
kdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of light
Not sure about Aston but Beru coils and plugs are OEM for Porsche. I use them on my 911 turbo
Old Feb 14, 2022 | 02:17 PM
Yes - and they are the 3 pin coil packs for the v12. I used them on mine when I changed them. Got them from Scuderia
