Foxwell NT510 Can Only See Two Modules
If you using the generic selection through engine OBD port, you can only communicate with primary ecu and trans, lacking communication to the engine secondary ecu? Also the comms you have with engine primary ecu have more live data than if using the Aston icon?
foxwell NT520
i saw this thread and thought it was the closest to what i am looking for. I tried running the update on the Foxwell and it is taking forever, any idea how long it takes? I saw a youtube video and it said 25 min, but mine is over 1 hour and nothing yet.
I'm sorry to hear that,you can contact foxwellstore.com customer service to get help,I know them
FWIW:
Good luck dealing with Foxwell. I went back and forth with them for three months, trying to return my scanner. They would typically reply once per week or two. It took a whole lot of "What is the reason for the return?", "How about you keep it and we refund your $20?", "What is the reason for the return?", "What is wrong with the scanner?", "What is the reason for the return?" emails before I finally gave up. I'm stuck with it and there's nothing I can do about it. It works great, if someone needs it. It just turned out to be not what I needed. Eh well. Let's say I won't be buying from them again.
Update the device to solve
I also encountered the same thing before. I bought NT510 from Amazon, Mine is a 2005 DB9, and found that only 2-3 modules can be read. After that, I returned the product and purchased NT530 again. But again, I found that there was no Aston icon. , Only the OBD II icon.
I looked for foxwell's homepage on Google and Facebook for help. A homepage called foxwelltool helped me solve the problem. (Their Facebook homepage often publishes some useful information)
They told me that I must register for a Foxwell account. Then download the software car type-in this case Aston Martin.
And they answered the question of "only read 2-3 modules", the solution is to update the device. The update must be done via a PC instead of a handheld device.
