Coolant smell, V8V N420
Old Apr 24, 2020 | 10:58 AM
mthdr's Avatar
mthdr is infamous around these parts
Hi,
There is a coolant smell coming from the expansion tank area after the engine warms up nicely. I can not find any indication of a leak and the coolant level in the tank is to the top. When loosening the cap after the car has cooled completely, it does gurgle a bit, I assume this is normal? Any ideas on where to look for what I am guessing is a small leak?
Old Apr 24, 2020 | 01:21 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
I had that same issue for a while until the leak where coolant tank is joined (top to bottom) finally was enough to see. Of course you might want to visually check all the hose connections ( small to/from tank and large radiator) as well as the radiator fo signs of a leak. If nothing , you might need to get the cap checked.
Old Apr 24, 2020 | 05:19 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
You can add a dye to the coolant that will glow under a black light flash light. It makes it easier to track down the source of a leak.
Old Apr 24, 2020 | 09:26 PM
eholster's Avatar
5 Year Member
eholster is infamous around these parts
The overflow / expansion tank is located in the wheel well, mounted low, behind the liner. There is a breather / overflow drain hose on it - maybe take a whiff down there? I had assumed the tank up in the engine compartment was the overflow until I removed the wheel well liner this eve.
Old Apr 25, 2020 | 10:14 AM
mthdr's Avatar
Thanks for those suggestions. I'll have a look this weekend.
TexasNewfie
Jun 26, 2018 02:06 PM
wa2fast
Jul 10, 2012 05:23 PM
@l996
Jul 7, 2011 12:18 AM
function12
Apr 1, 2011 05:25 PM
ptconner
Mar 9, 2010 06:02 PM
