Coatings for Car
No comparison on the self-healing and if you look at the clarity, Xpel has a lot of orange peel texture
Premier Protective Films
ClearGuard Alpha PPF, Spectra PhotoSync Nano IR & CeraLuxe IRD Tint, Coatings
www.premiermobilegroup.com
Sharing our Passion on Youtube: https://urlgeni.us/youtube/Premier
Facebook: https://urlgeni.us/facebook/Premier
42630 Christy St, Fremont, CA. 510-623-1308 sales@premiermobilegroup.com
Someone keyed this Porsche:
Hi all:
With the new weather, I am considering some protective coatings for the DB9. From what I can determine, there are three basic types: Wax, polymer and ceramic. There are also some hybrid coatings combining ceramic and polymer. I really have no clue. Whatever I end up choosing, I will also do my wife's 2002 T-bird ( so I better get it right or else I will never hear the end of it). What do you recommend and why? Any particular products?
It is best to do a paint correction before applying the coatings. These will last you at least 3-5yrs depending on how you take care of them. I would use Kamikazee Overcoat about once per 3-4 months just to rejuvenate the coatings.
Have you considered a full clear bra? Nothing that you've listed above will help with rock chips, if that's a concern for you like it is for me. In the past, for car shine and protection I have liked Zaino. https://www.zainostore.com/
I used to be smart when it comes to detailing, but technology has changed a lot since those days. What I will most likely do here soon is a full car bra so I no longer wince every time I hear pebbles/gravel on the road. As I understand, you can detail over these films if you like, but it starts to become overkill at some point. People with a lot of money will ceramic coat over their clear films.
If it helps gauge cost, $5k for a good full clear bra is a reasonable figure. You have to be very careful who you allow to do it though, as an untrained hand can cut into the paint when they're fitting the film. This was a great thread on it: https://www.6speedonline.com/forums/...ilm-101-a.html
I'd personally just get PPF and a non ceramic coating on top put on regularly. Ceramic Coatings per my dealer really only last them about two years before they start to lose the hydrophobic properties on the cars they did. A front bumper/hood PPF with high wear areas. Depending on your local installer it would be around 2K. I would never recommended STEK their authorized installer did a horrible job and the company wouldn't help when they their authorized installer messed up and wouldn't respond until a demand was sent for a replacement film as there were knife marks and it was poorly done. It's not the film as much as the installer and what film they feel most comfortable working with, but STEK is a tiny company with no interest in having the standards of other film manufacturers / resellers. Make sure you get a written or diagram of a car outing what will be done and if it's tucked etc like at the top of the hood. 3M hasn't failed me the in the past either installed at the factory or the dealership which was authorized, but I recognize there are newer options.
There are three types of installs --- Pre-Cut by plotter and program where the edges only go to 1/8 of the edge of the panels, Pre-Cut by plotter and program where edges are programmed to be longer and those are tucked underneath the panels, and custom cut where the installer cuts the film to where it is supposed to go. These vary in price due to the extra work involved. Not all edges can be tucked if not doing a custom job.
Installers is where the highest degree of scrutiny needs to be. I have seen brand new McLaren with cut marks all over the edges where the installer cut too deeply. This is not totally common but does happen often enough. The owners never know usually and only the second owner finds out when the film is removed. Sad but true. Experts can cut on the vehicle and be fine, but it takes almost years of practice. I prefer not too, i am not experienced enough so i know when to say when.
Film is great if you can afford it. If not then ceramic coat the vehicle for a much lower maintenance but better looking vehicle.
Hope all this helps, one of the members listed a thread I wrote above, i might need to look at it as i wrote it several years ago and things might have changed a bit over that time.
In the end, everyone has a preference to what they like installing. PPF installers typically only install PPF and dont get into Ceramic or paint corrections. Some shops do but you have to realize, PPF is where thier money is made so they will sell that as the premier product, the others are add ons that dont necessarily get the same attention.
When i did this type of work ( I do NOT now) I charged 2-3k for a front end wrapped for an Aston depending model or a 1 piece film for a new model Vantage or DBS, 1-2k for a paint correction, and 1-2k for ceramic coatings depending on coverage. So an owner who wanted a very perfect and protected Aston or any other exotic would pay $4k minimum depending on coverage of products. I knew shops that would say they did all that for 3k or less. But the work was no where the same in the end, regardless if the owner didnt know the difference on his own.
This stuff is all excellent - and has given me a lot to think about. Right now I am leaning toward a front wrap for rock chips and ceramic coating. Even then, there is so much to think about...things have changed a lot since the old can of simonize
You can do the ceramic coating yourself if you have some patience and some experience applying products. 22ple i have found to be the easiest without problems, which there are several when applying that can cause headaches. Make sure you research your installer for PPF and what product they use. Installer is more important than the product. Ask about knife usage on the paint, ask what to expect wen dealing with lift lines, silvering of the glue, dust or hair under the film. Make sure you have them say there will be none on the final product.
We recommend the following for any car owner:
1. Precut vs. Custom -
A) Not all precut installers are equal - look at work in person and do not rely on claims
B) "Certified Installers" to be honest, does not mean much. To get certified from any of the manufacturers out there really only means they took a 1 or 2 day course. Then off they go installing onto cars. History, experience are much more important
C) There is always a debate between precut and custom installations. Precuts are great for quick installs, but generally do not have as great coverage and seamlessness as custom. However, custom takes a much higher degree of installation skill / experience to achieve. One custom installer to another can mean 2 very different results - experience, experience, experience. Do not go by just claims of "xxx" yrs of experience. Many companies would tout 20+ combined years of experience....taking this example.....one company can have 5 installers with a combined 4 yrs of experience to get that "20" years.
2. Films - this makes a whole lot of difference. Some films like 3M and Xpel have a whole lot of orange peel texture. The clearer the film, the more difficult it is to install as films with orange peel texture tend to hide installation flaws.
3. Film's performance: These are things to look for
A) Clarity - look at it under fluorescent lighting. Also darker colored cars show the film's clarity or lack thereof more
B) Self-healing - product like ClearGuard Alpha for example does not require any form of heat to self-heal. Others need a heat source. To be honest, it is not practical for a car owner to pull out a heat gun to blow the film or bring in hot water to pour all over the car to achieve this.
C) Chemical etch resistance - this is very important if you get hard water, say from sprinklers, this can etch into the film.
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
If you have water spotting issues with your current water, please invest in a water filtration system what will remove contaminants and chemicals to prevent water spots. They will ruin your PPF and also cause ceramic coatings to water spot and both are a massive pain to remove. You can get these systems for less than $200.
Funny you say that because the Corvette community is exactly where I learned of Zaino. Haha!
Everything said above is absolutely perfect advice. ClearGuard Alpha is one of the top tiered films. I personally just prefer S-TEK who is also the leader in fashion films such as gloss black PPF or matte black PPF. Pre-Cut installations are fine, but it boils down to what is inputted into the computer and how the installer manipulates the program; such as extending the edges to wrap around panels. Not all programs are correct and good to use. 3M pro is good but has orange peel and glue is extra thick. Xpel is another world. It has orange peel also, but glue is workable. However, Xpel runs off name recognition too. From what i had gathered XPEL is now saying they will only warranty thier films IF thier OWN Fuson coating is applied initially, then once per year maintained by the installer. (the coating is junk IMHO; there is no dwell time when installing you have to remove immediately, gloss is less than noticeable) With most good coatings the applicator, within a few hours, hardens up and the more it hardens the higher the silica dioxide content was in the coating. The Si-02 is what helps to create the stellar gloss levels. What most people do not know is that while you can buy a Si-02 coating on Amazon for less than $25 for 30ml, it is a highly inferior product to the one that a boutique maker has for $125 for 30ml. Cheap coatings are cheap coatings. They have very little Si-02 in them and if they have any its a very cheap portion. There are different levels of the Silica used and price can be high for the best. Titanium dioxide is also now starting to be used by the best coating makers on the market. Its all in longevity and gloss levels.
Honestly my opinion almost changes per vehicle: rarity, collector, BLACK paint etc.... Rare or sometimes Collector i suggest traditional sealant and carnauba waxes; daily drivers and non special cars or cars that wont need to be kept perfect for 30 yrs can get the coatings no issue. Problem is anytime future scratches have to be polished out, cutting through the coatings sometimes removes more clear than necessary. So just dont suggest that on rare or future collector cars. Hope that makes sense.
My Black DB9 has the softest most easily scratchable paint i have ever seen. So i opted to do Kamikaze Coatings Miyabi x2 and ISM on top of all PPF surfaces, 22ple Trim on all trim black pieces, wheel well liners, 22ple on all metal under tray, muffler, exhaust tips, and for non-PPF surfaces i used traditional sealant and carnauba wax. (AMMO Skin and Creme) I did this so that i could very lightly polish the non PPF surfaces when i wanted and just reapply the protectant on those areas. I used the 22ple pro only Mistico Elemento coating on my RRS. And the 22ple VX PRO on my 1992 Mustang 5.0.
For somewhat normal people i would suggest (this is personal due to experience in using and totally able to be done by you with a bit of practice) is use either 22ple HPC coating, (i am trying the Insanity this week) or the Kamikaze Miyabi ISM combo for your long term protection. MUST absolutely remove each wheel, clean it, and apply the coating to the barrel and face during the coating process. This will allow you to wash the whole vehicle with soap and a microfiber towel only. No degreasers used. This will give you anywhere from 3-5 years or so for protection.
Rejuvenating the coating i would suggest the Kamikaze Overcoat applied to a Gyeon silk dryer towel and do that once per 3 months or so. More if you hand dry you vehicle which i never suggest. I suggest using a dedicated blower to dry them to keep from scratching the paint. 25% of your scratches come from washing the paint, and 75% come from drying your paint. Even using great products you have to be careful. Use a Big Boi or Metro drying machine ( GET THE EXPENSIVE one only, it will pay off in your time, and ease of drying) Goal is to not touch your paint.
Let me know if there is anything else you would like to know. ( Sealants such as AMMO Skin, Blackfire, Pinnacle, and Gyeon and other top of the line brands are mostly all great) I just prefer AMMO products.
Sheriffdep
Sheriffdep
Sheriffdep
And possibly a dumb question, but is there a reason someone can't use a strong leaf-blower on their car for drying instead of these blower vacs? Is there really that much of a difference between the two?
Yes, thanks Sheriffdep for sharing your thoughts. Your philosophy about what cars are best suited for coatings vs. polymer/wax is shared by many within the high-end detailing community (and myself). I just can't bring myself to coat my collectibles, even though my experience with Kamikaze products (Miyabi, Zipang, Stance, and Overcoat) has been exceptional. Have you tried their quick detailer yet?
Playing around a bit last year, I applied Overcoat on top of a polymer sealant. I was pretty blown away by the result. Perhaps its because my sealant didn't have the gloss I thought it did (Zaino), but Overcoat made the paint absolute pop. I really like the look, and since Overcoat is just a topper it's easy to remove. Does it offer the long term protection of a true coating? Of course not. But it looks incredible and there's no real downside other than cost.
