Aston Martin Clock Changes Every Start
Old May 27, 2020 | 08:03 PM
Freezie E's Avatar
Freezie E is infamous around these parts
Angry Aston Martin Clock Changes Every Start
Every time I start my 2015 Vantage GT the analog clock starts to change to 4:30 and then back to the actual time. I’ve tried changing time, turning auto time set off and on, 12/24 HR and battery disconnect.
Old May 27, 2020 | 09:57 PM
Gene G's Avatar
Gene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond reputeGene G has a reputation beyond repute
Maybe you should drive more than twice a year. LOL 😂
Old May 28, 2020 | 12:50 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Mine also does some funky spinning around, but does land at the correct time.
Old May 28, 2020 | 12:57 PM
Freezie E's Avatar
I've done quite a bit of looking but haven't found anything yet. Glad to hear I'm not the only one.
Old May 28, 2020 | 01:37 PM
J doubleU's Avatar
It reads time from the GPS system, perhaps its loosing satellite signal when asleep or in the garage. As stated above, at least it works.
Old May 28, 2020 | 01:45 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
the clock is normally a jewel in the dash, or is the newer model a part of sat nav..?
Old May 28, 2020 | 03:58 PM
cuddapah's Avatar
cuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond reputecuddapah has a reputation beyond repute
2015 DB9 here. I noticed it happen some times if not used for a few days. My guess is power supply from battery stops after few days and when unlocked, it gets power and uses GPS to set correct time.
Old May 28, 2020 | 11:54 PM
irvineboy's Avatar
irvineboy is infamous around these parts
It happened to me when my battery needed to be changed.
Old May 29, 2020 | 08:43 AM
Freezie E's Avatar
So once you changed the battery it stopped doing it?
Old May 30, 2020 | 07:06 AM
fineito's Avatar
fineito is infamous around these parts
My guess is it is a failing battery, too. I have a 2012 Maserati QP 5 Sport GTS. The Interstate battery was only 3.5 years old and on a Battery Minder. Twice within a month or two before the battery failed, I had to reset my clock because it reset to 12:00 pm upon start up. I thought, "Oh, Italian electronics", and went on my way. Well, the battery failed completely (while at home) and needed a jump start. No other advance warning offered - e.g., no weak starting - until it 100% failed. My tech told me that the clock freaked out because of the system's need to conserve power when the voltage gets low (I may not have that 100% technically correct, but you get the drift.) Flip the battery.
Old May 30, 2020 | 09:44 AM
irvineboy's Avatar
Yes it did.
Doug H
Apr 2, 2017 02:16 PM
Sleestak
Sep 20, 2015 10:10 PM
Brent Spotts
Jan 13, 2013 11:12 AM
Captain Tal
Dec 8, 2004 02:47 PM
