DB9 A/C Service
Old Jun 27, 2020 | 10:38 AM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
DB9 A/C Service
My '05 DB9 is needing the A/C charged. I'll take it to an indy shop. Are there any quirks to getting this done? Any lessons learned from the group? Thanks.
Old Jun 27, 2020 | 02:44 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Pretty standard R-134 system. 840Grams if memory serves. You could put a thermometer in the center dash vent, turn the system on full and record the temperature after about 20 minutes. Do the same after they are done. Mine blows 47 degrees and just did a full recovery, vacuum, fill.
Old Jun 27, 2020 | 04:15 PM
bobdisp's Avatar
5 Year Member
Thanks 4884! AM did not invent A/C for automobiles. I figured it would be straight forward.
Old Jun 27, 2020 | 05:51 PM
AM4884's Avatar
5 Year Member
I had to google it, but the 1940 Packard was the first car with factory air...
I would also recommend replacing the cabin air filters if they haven't been replaced lately. That will/can impact the efficiency of the AC quite a bit.
As always, YMMV!
Larry
Old Jul 2, 2020 | 10:45 AM
AstonCarma's Avatar
5 Year Member
AstonCarma is infamous around these parts
Yeah but you wouldn't be too far off expecting they'd put some special crap in it to make it cost $2500 for a recharge.
Old Jul 2, 2020 | 03:35 PM
AM4884's Avatar
5 Year Member
I have been meaning to check if it has a TXV (expansion valve) or if it is just a simple piston/capillary tube. It's old enough to be a piston (thankfully!)
Old Aug 1, 2020 | 05:13 AM
bobdisp's Avatar
5 Year Member
R-134a?
Old Aug 1, 2020 | 05:33 AM
AM4884's Avatar
5 Year Member
Absolutely. There is a label in the engine bay that give the freon type (r-134) and the charge weight.
850 Grams of R-134. Sticker is on RHS shock tower.
If your servicer drains the oil, it uses 5 OZ of PAG-46
Old Aug 1, 2020 | 05:45 AM
bobdisp's Avatar
5 Year Member
Thanks!!
Old Aug 1, 2020 | 10:14 AM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
We all us A/C in the summer. Best to runs the A/C some monthly (if at all possible) to keep the system lubricated.
Old Aug 8, 2020 | 05:13 PM
zzzamdb9's Avatar
5 Year Member
zzzamdb9 is infamous around these parts
I've been having intermittent issues with my A/C in my 2009 DB9. If I am driving in traffic, on very hot days 85F and higher I notice that my A/C will sometimes all of a sudden stop blowing cold air until I turn off the A/C and turn it back on. Sometimes, it works again right away, sometimes it takes a few minutes. A shop had checked my A/C last summer and did not find any leaks and suggested that I not use recirculate as the condenser could be freezing over. The air is significantly colder on recirculate though. Any ideas?
Old Aug 8, 2020 | 10:08 PM
J doubleU's Avatar
Is your ambient temperature on your display correct for the conditions? Easy DIY to change the sensor.
Old Aug 9, 2020 | 05:00 PM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Condensers don’t freeze over , that’s where the heat rejection takes place . So if this is truly what the shop said then you need a different AC mechanic . The evaporator is the cold coil and if the AC is working correctly with proper airflow over it and correct refrigerant charge it shouldn’t freeze over either .
First thing I would check would be the cleanliness of the condenser . A dirty condenser full of bugs and road junk will quickly cut down on your AC’s ability to cool .
Old Aug 9, 2020 | 09:37 PM
zzzamdb9's Avatar
5 Year Member
Yeah, the ambient temperature seems accurate.
Old Aug 9, 2020 | 09:39 PM
zzzamdb9's Avatar
5 Year Member
What’s the best way to clean the condenser? Use compressed air?
