Problem with HID on my '07 vantage
Old Jul 10, 2020 | 08:00 PM
jf.houde's Avatar
jf.houde is infamous around these parts
Hi everyone,
So during heavy rain, one of my hid went dead, I have switched right and left and found out that the problem stayed on the same side.
I then switched the ballast and fount out that the problem switched side and that my daylight are not leveling.
I now have two more questions:
1) Any aftermarket replacement available?
2) Why are my lights not leveling anymore?
Old Jul 11, 2020 | 04:42 AM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
To my understanding there is no connection between the ballast and the leveling.
Also I dont understand what you mean by "daylights" ?
Did you switch off ignition completely inbetween?
The leveling moves the whole inside unit, so both HID & high beam projectors.
When you first switch on the main lights, the leveling travels from a low (resting) position to normal position.
Also you there is leveling when you switch on/off high beam (level raised/lowered).
Old Jul 11, 2020 | 05:00 AM
jf.houde's Avatar
Yes I switched it off, by daylights I mean the hid.
Old Jul 19, 2020 | 11:43 AM
jf.houde's Avatar
Ok so here I was having two questions and solved one.
The headlight adjustment happens only the first time you turn the light on, after that they stay leveled even if you close the light but keep the power on.
As for the HID, could I just plus an aftermarket set of ballast and hid instead of putting chineese replacement?
LotusJPS
Jan 16, 2020 04:35 AM
TarHeelVantage
Feb 9, 2019 11:46 AM
Gene G
Mar 13, 2016 09:58 PM
britjon
Apr 10, 2012 05:24 PM
