Possible Caliper Rubbing -- what's the procedure for this?
Old Aug 10, 2020 | 03:22 PM
AstonCarma's Avatar
5 Year Member
AstonCarma is infamous around these parts
Hi everyone, my 2005 DB9 with about 7500 miles on the clock was making a weird noise yesterday as I drove through the neighborhood. It almost sound like a small bird was chirping as we rode along. My passenger got out and listened to my each of my wheels as I rolled and he said he felt that noise was coming from my driver side rear and thought I may have a sticking/dragging caliper. I ensured the emergency brake was disengaged.
Since I don't like putting my car into the shop unless absolutely necessary, I thought I'd check here since I haven't done brake work on this car yet. If I want to inspect my calipers on that wheel for proper function and determine if it's sticking, what's the procedure for this?
Old Aug 10, 2020 | 03:46 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
You may have a small rock stuck in or around your pad or caliper. I had it happen myself. I've heard of it happening to others too. It's worth a good self inspection.
Old Aug 10, 2020 | 04:16 PM
J doubleU's Avatar
It's the handbrake pads, changes with temperature, and sometimes when turning. Hold the button in and lift-up when driving to deglaze pads. Lots of stuff about it years back.
Old Aug 10, 2020 | 05:15 PM
AstonCarma's Avatar
5 Year Member
Do you recommend removing the caliper to do this? I have no problem taking things apart to better understand the car, I'm just pretty new to our brakes.
I assume just a light pull on the hand brake so as not to lock the wheels? What speed do we recommend doing this?
Old Aug 10, 2020 | 05:30 PM
J doubleU's Avatar
Whatever speed your comfortable with. Open parking lot 20-25mph. You can also slacken off the cable on the offensive side if your not comfortable with the drive n pull.
Old Aug 10, 2020 | 09:14 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Possible stone
Try a hard braking application while going in reverse; if you have picked up a stone or other foreign object, you may be able to dislodge it.
Worked for me a while back on my Vantage...
Conqueror
Mar 1, 2014 10:56 AM
MPac00
May 21, 2013 01:59 AM
steve harris
Apr 21, 2012 05:58 PM
nevert00fast
Feb 24, 2010 05:22 PM
500
Jun 18, 2007 10:57 AM
