I read a lot in this forum ppl trying to use Bovee and others that had to pay a lot to be able to listen to some music of their phones...
Here is what i have been using it for 2 years with no problems at allllll. it probably cost 30$ i have it plugged to the trunk lighter so its hidden set it up on a radio frequency, set up the FM radion on the same frequency and taraaaaaaa u can now connect to it via bluetooth and play all the music that u like of ur phone, I hope this helps somebody.
there are a loooot of models out there just pick the one u like and use it.
Search lighter radio transmitter
never really had great experience with those FM modulators. Have to always switch channels due to signal congestion.
Get yourself one of those mr. 12volt units instead, meant for Volvo. you can find on ebay. $120 for modern BT connectivity.
Thanks buddy, maybe in here we dont have much channels that makes it a bust but been using this for nearly 2 years with no problems what so ever, I thought ill share...
i've had good experiences with them too. but the mr12volt (with the DIY install) is a bit slicker, although it does mess with the CD player, and could be an issue. but for 10-15 bucks? it's quite a value and a very clever device too.
BTW, both the mr12volt and the fm thing-a-ma-jigs work with your phone too. the phone call sound comes through your stereo.
These little guys are amazing! I had an old version from back in the 90's that would barely hold a signal for 5 minutes... but the newest ones are brilliant.
I have a couple of these Nulaxy units:
And they work flawlessly with no channel drops or interference. And you can use them to charge your phone, answer the phone handsfree and mine even has a "base booster" that is great for when I want to listen to Prokofiev! There's a thumb-drive port too....
